We all know the RB26's are a GREAT engine and its something different however you would want decent suspension, better brakes (no point going fast if you cant put the power down, corner and stop!), gearbox / clutch etc
You could probably have yourself a reliable engine with decent mods and ecu for 18K?? Nothing too hardcore and then spend the remaining on all the non engine stuff!
yeah there are no problems there, brakes slotted, steel lines, upgraded booster, and gone to twin pistons cals, Koni strusts, koni suspension, king sprins, 2" lower, nolaphane? bush kits through out, aswell as panard rod, sway bars and two strut braces. sooo i think suspension and brakes are sorted :)
plus when i get a pair of 19" rims, i'll upgrade rotor size,
so you are thinking 18Gs for cams, turbos after the half cut? or including the half cut? 8gs for a h/c, sorry for sounding stupid, but i got now idea atm an RB part prices.
Good to see people actually THINKING before modding a car :)
No point going fast if you cant stop!
I have NFI on prices either. Would it cost 10K to rebuild a reliable RB26 with a single turbo conversion?
say another 8K on on turbos / cams. FMIC etc? Since you dont have to do all the brakes and suspension you would then spend the rest on decent ECU and tuning and all the misc bits and pieces?
I would probably go speak the the guys at Hyperdrive. They seem to know nissan engines :rofl:
Hey thanks for that, even thinking about mini tubs i can get 245s out the back, but i would like something i little wider for slicks.
Hyperdrive....... where bouts r they in perth?
ok..... so wots a better choice, and R33 or R32 and why?
R33. Purely because they are newer and have different cam specs and tuning. The power output is the same but there is more torque. It helped compensate for the increase in weight of the R33. The only drawback is that the computer is sealed an you will not be able to modify it. This won't be a problem if you are going aftermarket.
What about RB30det?
For the cost of a 2nd hand rb26 you could build one and not have to worry about the condition of a old motor.
Imo probably cheaper and a lot less mucking around for a better result.
Or sell yours and buy one already done
http://antilag.com/forums/showthread.php?p...45825#post45825
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
