  • Replies 148
Posted Images
If you can get Mahle pistons for an rb26 or even rb25 I would really like to know those part numbers, Mahle are the best no questions... I have been trying to get them for the rb for the best part of this year but with no success, another thing to remember is alot of mahle designs have really short sides or skirts more or less none they are just the crowns this is aweseome for power but not really longevity as they arent as stable in the bore. They are good though... ACL are just replacement type pistons they are good but dont offer high end forgies made from good materials like some of the other companies, but again they serve there purposes!!!!
What are the brands of forgies available and what is order of pricing?
Arent ALL forged pistons as good as one another because they are forged or are there different types of manufacture, composition and therefore durability?
I here a lot about wiesco, arias and JE but I would really love to know, as stated in my first question what all the brands that are available and the pricing of each.
Also it would be nice to know what piston you chose and why you chose it?
I have put together chat I can from this forum but I am still confused.
Cheers
Stay away from the ACL / ROSS forgies as they are noisy as and recommend a 6 thou clearance which seemed acceptable maybe 10 years ago.
OK so what do you guys recommend then if you can, answer the questions I put foward before it would be great... cause I just dont know what to get :confused:
Cheers
I think I've posted something before about this, We've used Arias, CP, ACL/Ross, JE, Venolia, Wiseco and SPS pistons in RB engines and never had any of them fail because of piston design or material problems.
Some have advantages and disadvantages, from my experience Arias are a nice piston, well finished but the rings supplied are a little ordinary. CP are a very nice piston, the same sort of quality as JE and both run fairly tight clearances. Ross makes most of ACL's forged "sport compact" style pistons, these are solid, great sizes, really good rings but do run a little extra cold clearance because of a lower silicone content which does make the piston a little tougher. They are also a bit heavier than others. Venolia pistons are tough as nails but run big clearances, a little more than ACL/Ross. Venolias are supplied without rings and there are some pretty ordinary ring sets being sold with them, some even with a cast top ring. Wiseco pistons are excellent all round, well finished, good balance, great ring pack with narrow 1.2mm steel top rings, round wire clips, most have coated skirts and small cold clearances. SPS make great pistons, they are a little dearer than most but they will make exactly what you want, whatever ring style you want, weight etc..
With the cold noise issue, as a rule of thumb, the lower the silicone content of the alloy used the tougher the piston will be, as the silicone content increases, the clearance decreases but the piston becomes slightly more brittle. There are other advantages/disadvantages of different silicone contents and people will argue until they're out of breath what is better but really it depends on the application. For a street engine that is driven regularly and doesnt get a proper warm up something with a slightly higher silicone content will work better as the piston is more stable in the bore even when cold. For a race car this doesnt matter as much as the engine is warmed up before it is driven.
Materials are improving, most of Mahles range now are extremely strong and run tiny clearances, their Subaru pistons are only running .0025" clearance which was pretty unheard of a few years ago for a forged piston. Eventually they will be available for most models but currently their market is dictated by what sells in america, so Subaru, Mitsubishi, Honda and Toyota are well catered for. They will make custom pistons for anything but it's a slow process as their production is dictated by Nascar customers as that's their biggest market so custom orders can take a while.
I got JE VG30 Pistons and the gapless rings for mine , I wanted 87.5mm and 22mm gudgeon pins but mainly the higher compression ratio ie up round 8.8 - 9 to 1 . I don't know what clearence is recommended for these as the build is not too soon . Fingers crossed those Sealed Power rings will pay off .
Cheers A .
Thats interesting, I have a set of ACL forged VG30 pistons ready to go here as well. What are the advantages of the gapless rings over normal ones?
I always assumed the ACL pistons where Mahle, after reading all the posts here maybe they are made by Ross.
Sorry to ask for an education on this, but I would like to know. :rofl:
Thats bad, I think I would walk around the house majorly depressed if that happened to my freshly built motor. :D
Have you got a gut feeling on what it may be? Tuning, Machine work/assembly or support system failure? :)
not sure what the cause is yet. The car was running 0.4bar and rich. The failure seems to be heat related tho as it was on my first 30min+ long drive. Don't you hate it when the machine shop decides to use closer clearances then you asked for and then you get the "warrenty covers oil leaks only mate"
Its a well known fault Matt
Venolias are a very poorly designed piston. Did you have a good look at the underside and skirt design of them before you bought them?
The skirts are very thin, too thin in fact and there is a groove machined around the outside of the piston that even further reduces the overall skirt thickness leaving a weakspot. This is where I have seen them crack.
The last piston that I looked at which was pulled out of a freshly built RB26 was cracked in such a way around the skirt that a peice the size of a 20c peice was ready to fall off :thumbsup:
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
