  • Replies 148
Posted Images
If you read my earlier post I brought this up as well.
Mahle actually own ACL. I have ACL pistons and always thought they where made by Mahle.
But a few people have said they are ROSS pistons. Now I am really unsure.
We need this clarified I think.
My engine builder said i am using mahl pistons but they came in a ACL race box so not sure
The ACL piston in the photo above is made by Ross. The milled spots under the head of the piston is where they normally have the Ross brand. They also use spirolox where mahle pistons use round wire clips. All the mahle performance pistons are a dark grey colour rather than shiny alloy. ACL don't really try to hide the fact, they also supply Ross with the piston rings they supply with their kits.
The ACL pistons for the RB26 are a little too thick in the skirts in my opinion, you could lose a fair bit of weight without losing strength. Compare them to a Wiseco or JE and you'll see the difference.
I quick question for those that know.
In the Z32 there are squirters below the bore that direct oil up into special holes in the piston crown to keep the piston cool.
Do the stock GTR and GTST pistons have that as well?
I notice on the ACL forged pistons I have they are missing. I wonder if it makes any difference?
GTR pistons have cooling oil channels under the piston crown, GTST do Not.
B33st- No. 3 is 100psi the rest are 155psi. A teaspoon of oil brings No. 3 up to 155psi.....so looks like definate piston/bore or ring issue unfortunately. The head is coming off this weekendish.
Can u guys tell me much about the N1 blocks, just jap have one for $3500. Do the normally come with pistons etc?
Also any info on N1 pistons regarding strengh, price etc?
Nah you only get a bare block :rolleyes:
You can order brand new N1 GTR engines from nissan and various other companies for about $12,000 but this doesnt include any of the ancillaries.. wiring.. etc
Just had a good chat to the guys At ADVAN. They said 2.5thou clearence was fine.
Venolia were crap,
Arias are good with the iron rings as the bed quicker.
Don't use the 1.5mm restrictor in the block as it causes the cams to sieze unless the N1 oil pump is used,
Use a semi syn for run-in and half throttle to 4000rpm over 500KM.
Compression is best around 8.5-8.7
The head is coming off on Sunday, pix to come.
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
