Arias Pistons
BOOSTD
 Share
  • Replies 148
Posted Images
You are mxing up metric and imperial systems
0.010mm is 4 thousandths of an inch.
Im not sure. Take a look at The Venolia Catalogue why would they use imperial mesurements all the way through then go metric when detailing the Piston clearances.
as far as i can figure 0.010mm is not 4 thousandths of an inch
1 thou...0.001"
1" (25.4mm) / 1000 = 0.0254mm
so
4 thou....0.004"
0.0254mm * 4 = 0.1016mm
and
10 thou...0.010"
0.0254mm * 10 = 0.254mm
is this right or am i confused????
.010mm is 4 ten thousanths of an inch.
.010/25.4=.0003937"
I'd run the pistons with the clearance they have built in to them, maybe .0005" less for a street engine.
Remember that if you finish the bore to smaller than the nominal size, every .001" smaller in bore size will close up your ring gaps by around .003" (using Pi*diameter)
The Venolia's run extra clearance cold as they have a lower silicone content that others and have a greater coefficient of thermal expansion, so when they are hot the clearance will be similar as they expand more and take up the cold clearance.
To convert mm to inches-
multiply mm by .03937
To convert inches to mm-
multiply inches by 25.4.
Totally agree with you PROENGINES.
But i do not agree with:
Stay away from the ACL / ROSS forgies as they are noisy as and recommend a 6 thou clearance which seemed acceptable maybe 10 years ago.
I hace an RB26 ACL/ROSS piston in front of me.
Reccomended clearence .12mm (.0047")
That is 4thou and 7tenths
.010/25.4=.0003937"
So pro engines what clearance would you / have you run the venolia RB pistons.
Any more updates BOOSTD?
Yes, The gudgeon pin on number 3 has come out the side of the piston an scored the bore quite badly. Number 6 also has a 1mm line down it. The pistons are still in the bottom end at this stage. It will be interesting to find out if the circlip was installed, failed or forgotten. If the later is the case I will post up the workshops name.
I have taken a stack of pix, just need to find my USB cable.
Matty
PS. I'm most likely going with CP pistons if I can find a cheap supplier. If not ARIAS are my number 2.
Edited by BOOSTD
Boostn32,
I was going to assemble my motor myself. I was told for $300 the bloke who was doing the machining would assemble it.
The cost isn't in the assemble its in the machining.
Its not about being loaded its about aiming for sensible goals... 350-400rwhp out of an rb20 is simply silly, especially if you don't have heaps of cash to throw at cams and headwork.
For a drifter all you will need is 220-230rwkw, with that sort of power it will be much easier to drift, having a rb20 that comes up on boost from 6k isn't going to be a very nice drifter.
Possibly forget about the rb20 all together, sell your rb20det and buy your self a r32 rb25de, drop a set of forged pistons in that and enjoy your 350-400rwhp, it will be much more reliable as it doesn't need any where near as much boost and as many rev's as the rb20 would.
ok, im not giving out details on my engine build at this stage as everyone knows its not easy to get 350 - 400rwhp out of a rb20. its more of a chalenge than other motors and thats what i wanted. lets just say the engine is far from stock. just wanted the finer details to make sure everything is right.
i just want to do it right hence why i was asking about the rings on the arias pistons. we are all here to help each other out i thought.
 Share
