T04Z is regarded as the biggest you can go before you need to upgrade mountains of crap Matt.
yea I know hence I dont see it coming on at 3,500rpm to make 760hp...despite this I wouldnt be suprised if it is making 800hp that its broken at least a gearbox/tailshaft or something....thats all im enquiring about.
  • Replies 153
if anyone acts like a tool we will throw them out, its just about having a good time.
Does that include if you want to drift around the track.......... sorry but that is what I'd want to do, going fast has lost its sparkle, its all about the drift for me now.
Hope you all have a fun time though :).
Club members could compare kw @ teh wheel though before they hit the track, the day before this is a club dyno day :)
780hp at 3,500rpm?....is the car even on boost at this rev range I imagined a T04Z coming on pretty late? I take it you dont drive this car around on the street all the time, 25psi of boost would require quite a substantial amount of fuel support and hence im sure the bill would be huge. Im also assuming you are talking about a HKS T04Z? May I ask how your going on gearbox's/tailshafts/diff's etc?
Broken a couple of gearboxes and not standard ones too ,the diff and tail shaft has been fine ...knock on wood ..lol with te to4z which garrett made for hks and hks developt more on it ,its only a t4 turbo and a good one which produces very well horsepower at early reves ,i proberly confused you ,i mean boost comes on at 3500 reves ,which is a good set up for over all racing and also depends on how your motor is set up too ,..i know of some people it comes on about 4000 plus ..
with my motor i could have bigger turbo producing up to a thousand horspower but bloody useless for track set up when boost comes on 5500 reves plus, no good for cornering and uncontrolable ..good for drag set up ,only if you got nos to stop turbo lag and a good ems to run it ..plus the fuel bill is not too bad unless you put yah foot down and it s on 25 p at all times due thats how motech is set up or tuned ,and motech dont have electronic boost controller it has everything else but that ,..i dont know why ,its ment to be the best ,but its worked real well 4 me and keeps the car running very well ,if you can find a good tuner that is .who knows motech ,as not many do .
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
