Munch, Munch I had a piston for lunch :(
I'm a dickhead!
C. Should I go to Racepace (I know Ben is great @ rebuilds) or leave the work to the dude who has my car at the moment (Cromwell Auto) does allot of rally cars (WRX's and good old 120B's)
:rofl:
Before someone else jumps in, let me say this :
Take it to Ben.
:rofl:
  • Replies 56
damn :rofl:  start saving :P
I just started mine on the weekend for the first time after rebuilding it and it has been....interesting.
My recommendations:
Go Arias forgies, about 1200 from Rocket industries including rings.  86.5mm will require a small bore out
Head recondition, new guides and stem seals, get the ports cleaned up a little at the same time
Standard rods should be fine.
ACL make bearings for rb26 now, about 10% of nissan cost.  SR20 big end bearings and RB30 mains.
Whack on a trust exended sump, or even better a local custom made one that won't reduce ground clearance
Balance all the uppy downy roundy roundy bits
Might as well throw in an N1 oil pump but I would not do N1 water pump unless it is a track only car.....they flow a fair bit less by the look of them.
I thought Arias pistons were $1200 from Rocket Industries aswell, until I ordered them... they added GST ($120) and delivery ($30) = $1350.... :rofl:
someone please send me bens contact # too please!
Ben Derks @ Racepace 9762 9421
Robin May want to upgrade the oil pump collar to the larger R33 collar as I've been told that they can fail at high RPM (R32 crank collar to drive oil pump is *apparently* too small) :rofl:
Robin
sorry to hear it. don't go overboard on N1 pumps. The standard oil pump can be upgraded by fitting a 50c spring in the pressure relief and suddenly it's an N1! Actually, going through Fast I discovered that GTR33 and 25t pumps flow exactly the same volume/pressure and have the same part number. Thats gotta hurt the price of GTR oil pumps! The N1 water pump is good for consistent high rpm application, and as yours is a daily it is not worth the effort, even for track unless you are intending extended lapping sessions. Being an R32 it may be worthwhile getting the oil pump drive collar on the crank fixed up to prevent any failure there. Otherwise, Ben is as good as it gets for a spanner man and he should be clued on these issues.
Robin
Geoff's right on the money!!!! I was working on a budget with my rebuild and Ben recommended modifying the relief valve, and now she flows like an N1 oil pump!!!!
R32 crank collar is definitely a known point of failure in an RB26. I have pictures of how they wear at home if anyone is interested
-Patrick
-Patrick
Would appreciate some pics - if you can't post them up here pls email to [email protected] :)
JAG - what sort of budget were you looking at to get it to spec? I'm thinking with the ECU and everything else spending around 3.5k to 4k + 20% for extras. Would love to keep the cost lower if possible but does not look likely. Also, probably need a tow down to Racepace...any chance of getting a lift from you?
Robin - I'd allow more than that, mine was around $5k from memory, without ecu.....
As far as tow no probs, just let me know when you need it moved and give me a call on 0419877437.... Might want to check with Ben first when he can accept the car....
Cheers
ohh Robin so sad to hear my thoughts are with "XXXGTR" may it come back stronger than ever.
i dont know much about engine rebuilds but i would have to agree with Jack when it comes to price, as i have been looking at different bits and pieces and it quickly adds up. dont forget to add labour as well.
but i just wanted to add as far as ECU goes i know alot of people recomend Apexi Power FC's but you might wanna talk to Sam at XTC performance in Coburg, as he has the software to re mapp your standard ECU to the same out come as an aftermarket, but it will still have a sensor (knock sensor i think it is) to retard the engine if it ever has a bad tank of fuel or somthing like that.
well any way good luck and dont stress it will all be fine.
Having tried 3 Melbourne tuners since being in Vic...id recommend spending the $1200-1500 on a PFc and getting the car tuned at Racepace. You can get 2nd GTR Pfc for around $800
One tuner i was pretty happy with considering the time they did it in, good power when on boost, nice driveability, idle. Its just that on low boost it didnt make any power at all, and it got crappy fuel economy. And the ignition seemed to be retarded a little too far meaning water temps ran 3-4 degrees higher then usual.
Id go so far as saying that the $1500 odd for Pfc and Racepace tune is better spent then getting std ecu re-mapped and running aftermarket rods.
Dont skimp on tune...especially if your going to keep the car honest when its rebuilt by gettig up it:)
Can't really get my head around what it is I want within a resonable budget. Looking more expensive than original plan... either way, where there is a will there is a way!
I think my biggest drama is working out weather I want to go down that road and turning the car into a weekend racer (what I 'd love to do in time) and get a run-a-round or keep it as my day to day transport (which is also very nice... nothing better than jumping in the GTR to go to work in the morning, makes for a nice start to the day - missing that at the moment)
I think at the end of the day I will need to keep it real and get the car on the road ASAP as I do not have a back-up. Looks like I need to crunch those numbers again :(
All the people asking for contact details, there is a sticky thread at the top of this forum, with all recommended workshops listed.
http://www.skylinesaustralia.com/forums/sh...&threadid=13305
Robin: Guess you should write down the 2 different options
1. Built it into a weekend car/track car - write down what you would like the car to have/be able to acheive, work out a timeline for it and budget for it
2. Keep it as a daily driver and track car - write down what you want out of it and work out a timeline/budget for it...
if you go for option 1, then you would probaly want to buy a run around shitbox right away so you don't have to stress about getting the GTR back on the road ASAP, you can do reasearch and think about it more.. if you go for option 2.. then i guess you need to get into gear.... I'd probably do(and probably will do when my engine goes) the same thing Jack has, forged pistons, and whatever else ben recommends for a daily driver, sometimes track car. Probably budget around 6k for the engine rebuild not including ECU etc..
Had a good talk with Ben this arvo and my car aint going nowhere soon... I have to find a small fortune as soon as I can. See you boys on Sunday, whoever is going down to Sandown... otherwise, see you on the road in a few months ;)
Grey St... ?
:cheers:
Try not to stress, its not the end of the world (yet) :)
Hope it goes well..
OH and if you want a daily driver I have a Gazelle I need to sell one of these days! (been lazy)
edit: DOH logged in as 46n2
-Kaz/hellrazorette
Sorry to hear mate about your engine mate but I'm sure with some time and money all will be well, just sucks about the money bit but a lot of us know the feeling also.
I'd recommend a Holden Service center for the work persoanlly......hehehe, just had to be different.
Nah but really, if you need anything let me know, lifts etc (if you go with Benno). I live very close :)
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
