complete r32 gtr interior
front seats rear seats door trims rear trims 1200 ono SOLD
cluster/instriment panel speedo goes to 260km $200ono
all 4 lowered springs and struts
AVS Model 5 White Rims 235/45R17 tyres $1000
rb20det/ turbo/ecu/manual 4wd gearbox/loom 1200ono 4 whole package pm 4 more info
other undamaged stuff
auto to manual converson parts 300 ono
4wd computers
ps pump $50
aircon compressor $50
radiator $100
side indicators $30
dash wateva :D
diff $200
carpet $50
door sil trims
rearlights
crossmember
all 4 brakes/disc's caplipers waterelse ya need $500
every single panel is dintted in some way except pasanger door
ALSO GOT R33 GUARDS MUST GET RID OFF BEST PRICE GETS THEM
ALL PRICES ARE ONO
anythin else just ask might still have it
$100 donation wil be made to sau once all/most this stuff is sold
  • Replies 80
Hey man,
Are you using a GTR dash????
Chasing the dash surround with the didgital clock..... has wiper controls and head light controls on it..............
Its the plastic fasica that runs on the edge of the instraments binnicle.....
Mike
In the dash - the two top defrosting vent inserts (the two vents that run the length of the windscreen)... got them?
Order them tru nissan, i did, u get them knew and they arent that expensive...
the point i was trying to make, sorry for hijacking the thread, thought it could help a few people out tho.
Oh yeah old mate, i would take your interior but im not in sydney :(
26GTS :cheers:
How much for GTS4 front & rear diffs (must be 4.3:1 ratio)?
How much for GTR 260klm dash?
Get back to me ASAP, Thanks.
front seats rear seats door trims rear trims the center console bit  1200 ono
also have cluster/instriment panel speedo goes to 260kmh
wreaking gtst4  everything 4 sale
lights broken front guards damaged
roof squashed
has coil overs  $700
17 inch AVS white mags n tyres $1000
rb20det/aftermarket turbo/after market ecu/manual 4wd gearbox/loom   $2500  4 whole package pm 4 more info
everything :cheers:
anything else give me a yell may have it
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
