Hi all I wish to service my trannie so I thought why not do the valve body upgrade that ppl have been talking about. As I am in Darwin and these things are not easy to obtain. I heard that they are about $350 for the upgrade. I need to know of the part number and where I can buy one and if I will need to buy the filter as well if not part of the upgrade.
Any help would be great and it may be worth while putting it on the parts list.
:D ICE
https://www.sau.com.au/forums/topic/68715-valve-body-upgrade-for-my-stagea/
