hey guys.. i just bought a r33 and i do not know much about these cars as i use to drive a 180sx.. newais i am wondering if it is bad runing 2 bovs? i have the stock one still on and an aftermarket one.. i have been told to remove and block the stock one... How do i remove the stock bov? my car idles normal and fine..anyone have pictures or sumthing to show how to block the stock bov or remove it? thanks im a noob lolz..
https://www.sau.com.au/forums/topic/68731-how-to-remove-stock-bov/
  • 2 months later...
good morning newb.
2 bolts where the bov attaches to the crossover pipe. remove large plumb back hose, remove boost signal hose. Block off plumb back hose. Signal hose can be used for A/M bov. get a metal plate, drill 2 holes to match those on the cross over pipe. and bolt it on with some sort of rubber seal to stop leaks.
Or you can leave it on and make you car a look a little more stock.
I am running 2x BOV's at the moment.. one stock and the aftermarket..because it came as part of my intercooler piping. The Blitz one doesn't open really at all (much stronger spring), so you do need to block the stocker.
Like chef said, some plate metal, some tin snips and a drill should do it. I actually built a blocking plate for the Blitz as blocking the stock one has been known to cause idle problems.
Might put the blitz back on when I am running higher boost and you can actually *hear* it :D
  • 1 month later...
