just went for a little drive, nothing strenuous...
then my car started to rev out once it hit 3500RPM... like it would accelerate fine up to ~3500, then after than it just revved, but seemed like nothing be transfered to the wheels, as if i had the clutch engaged...
now its a twin plate clutch (nfi on brand, was in the car when i bought it) nfi on age either, altho im lead to beleive its sub 12months...
when i stopped at lights with it in nuetral, taking off the clutch seemed to be fine for a bit, then ****ed up again... like it had the normal 2 grab points... then taking off without a prolonged stop, it would only have one grab point on takeoff...
the gearbox oil had redline shockproof put in it last july... could old/lack of oil be the problem? or has the clutch shat itself? :rofl:
thanks in advance.
:rofl:
https://www.sau.com.au/forums/topic/68732-slipping-clutch/
had this problem a few years ago, it's a slipping clutch orright, had to get a new clutch shipped over from Japan when that happened to me, put me back a few hundred dollars. Lucky for you it's an R33 so finding one wont be as hard. I'm pretty sure it (mine) was over 12 months old though.
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1273443
well, after speaking to ken at hyperdrive this morning, and cringing over the price of a replacement twin plate clutch...
he told me to basically go thrash the car thru the gears for a bit.. to which i did, and my clutch seems to be fixed! rang him again, seems like oil or something may have been on the plates/flywheel... going to see how it goes in the next few days and hopefully ken just saved me $1000 by telling me to thrash what seemed to be a broken clutch :)
you know its good when you have to thrash your car to fix it :D
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1274479
well.. on the way home it decided it wanted to sort of do the same thing... but i couldnt really thrash it, lack of tread + rain == slippery skyline... cant tell if its reving out, or spinning the rear wheels half the time :D
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1274968
update...
after just trying some more stress testing.. it went weird... all out flooring it, quarter mile style, it went pretty much fine... however cruising in a gear, then planting it and dipping the clutch sees it bouncing off the rev limter and not coming back down or transfering anything to the wheels... and normal driving was pretty bad, and takeoffs were rough as hell, have to launch at ~2500-3000rpm to get it somewhat properly, any lower and it vibrates like hell :(
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1275305
update...
Sounds like a bit of a problem if it's still happening, if you do have to replace it go heavy duty. Get something strong that won't get you like this will.
Still hope it works out for you though!!!
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1275356
ken reckons an xtreme single plate brass button clutch and lightened flywheel is going to be a much better option for my car, and about 1/3rd the price of a replacement twin plate os giken with standard flywheel....
Strisch9 - my clutch pedal used to be extremely hard, and is still relatively hard now, im taking it to hyperdrive some time next week to let them have a looksee and tell me what the verdict is, i just want my clutch working before i try venture 500km to geraldton.. and then back :(
and then if i do get my clutch done, will most likely get my ECU retuned while im in there, having unburnt fuel all over the back of my car is kinda sucky...
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1275507
you know what.. i just have had the same problem. I was driving fine.. then put my foot down in 4th to overtake, it started picking up then felt like it starting slipping (or spinning the wheels but im pretty sure slipping). But seemed fine .. then did it again. Wierd. Maybe the change in the weather doesnt suit out skylines :)
Hopefully it'll correct itself
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1276438
a heavy duty single plate puck clutch isnt an improvement on the twin plate that is already in there. Look at having the twin plate rebuilt if that is the case, do not let the workshop retain the twin plate, even in warn guise they have some value.
argh, and twinplates come with their own *usually lightened* twin plate. Try and do some research into what twin plate you have and replacement plates of them.
CHeers
Sean
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1277352
it may not be an improvment, but im better off with a single plate...
my car only has 200rwkW, doesnt *need* a twin plate, not to mention i work in ossy park, start/stop traffic is an absolute bitch with my current twin plate... then there is another thing called money... $2700 for a new twin plate installed, ~$1500+ for rebuild, or ~$900 for a lovely new smooth single plate clutch.
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1277376
haha i dont think the single is going to be smooth
smooth is a full face organic clutch that allows a bit of slip (seen on OE cars)
your ceramic button clutch is going to be strictly off/on (depending on the amount of pucks/paddles they chose) until you wear it out a bit :rofl:
theres a good chance its gonna be harder to drive than your twin plate
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1278054
Bullshit.
https://www.sau.com.au/forums/topic/68732-slipping-clutch/#findComment-1278547
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
    • That's how it seems to me to. For the people that want huge power RBs (which it has been shown to do), this is great news, but that is not the same as trying to bring an rb 30 years forward....its not clear that there is a market of people who would pay 10s of thousands to do that
