Just wondering if anybody has had their radiator done locally, either repaired or replaced, and can recommend a place? Somewhere close to the city preferably.
Also, does anyone know if the top plastic tank can be replaced, or if the whole rad has to be done? I managed to snap the top pipe in half just pulling off the hose :rofl: , but the core and everything else appears to be ok.
Oh, and it's an R33 GTS-T if that makes any difference.....
Any help would be much appreciated.
https://www.sau.com.au/forums/topic/68746-radiator-repairers/
Also, does anyone know if the top plastic tank can be replaced, or if the whole rad has to be done?  I managed to snap the top pipe in half just pulling off the hose  :D , but the core and everything else appears to be ok.
Hi JD_R33
the exact same thing happened to me not long ago, I got the top tank replaced at natrad.. I think it's just over $200 if you take to radiator to them and around $300 if you get them to remove the radiator as well.. that's the price for my r32 anyway
Thanks for the advice guys.
In the end I decided to just replace the whole thing, so I wouldn't have to worry about it again for a long time hopefully.
Ordered a new rad from Kool Kore at Fistwick today, should be here tomorrow - cost was just under $400 if anybody is looking to do the same.
Add that to the $300 I just spent on the brakes and another $130 or so on kits from Jaycar and it's been a big week. These damn cars are almost as expensive as spouses :)
    • You know, that is exactly the thing that I was thinking a coupe of hours ago. I even had a plan for a meme, involving one big one, another big one, and the Old El Paso girl saying "¿por que no los dos?"
    • NoS, 2 of the big ones.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
