I have for sale 1 XF Falcon throttle body. They have been de-greased, cleaned and oiled. Come complete with throttle cable bracket and throttle position switch. Asking price is $100 but am open to negotiation. PM me or email me directly at [email protected].
Pictures are available on request
cheers
Tim,
Edited by PHaT MR30
Angry: As far as i can tell you these will NOT fit on a std RB20/25 plenum as they are physically too big and would foul on the rocker cover.
Richard: I am aware of the difference in size between the S1 and S2 Xf, will put some calipers on them tonight and find out.
one is now listed on ebay also
measurements
Outer front opening = 80mm diameter
Inner front opening = 72mm diameter
Inner rear opening = 68mm diameter
Butterfly = 68mm diameter
The bolt centres are 67mm left-right and the same (67mm) up-down where it bolts onto the plenum.
a pic of the rear to for you guys
Yep front facing plenum, I am putting one on a GReddy inlet manifold.
did some research and from what i can tell the only difference in the TB's is TPS, there is two different ones as pictured.
there is another one, but this is totally different and in fact an oval shape... i assume this was for the single point injection setups
  • 1 year later...
Will get a pic for you in the next few days, obviously the links above no longer work and ill be damned if i know where the originals went!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
