My R33 is getting registered soon (after 5 very long months of waiting) - I would like to know any potential gotchyas that could prevent my car from passing.
Its got a couple of eye-candy mods like drilled pedals and a really stupid boost gauge setup (there is a plastic pipe running up from under the passenger dash to connect it up). Do these mods cause trouble when the car is over the pits? Anyone had trouble when registering the car and have some tips to make it go a little less painful?
Cheers,
Steve
unless the pedals are factory they might tell u to take them off? ive had problems with that b4..
the guages im sure someone else can fill u in on...
are all 4 rims and tyres the same? the sil wouldnt pass unless we changed that. also get permits if u have pod, BOV, strut brace, cooler and stuff.. thats always handy and best to get if it passes the first time :D
As far as I know, the car has to be 100% stock when it goes over the pits, and when it has been registered the workshop can get their stuff back & give back your mods. So the pedals should be switched over & the gauges removed (by the way the setup sounds, get it done again properly) & any other mods changed.
this is registering , not RAWS compliance . the car does not have to be %100 stock , only meet roadworthy requirements . Even then stuff gets through RAWS , my line had aftermarket suspension and got complience .
drilled pedals have to have grip , cant be a glossed or painted surface . %90 of the pedals on the market wont pass .
guage doesnt sound good . technically I think your not allowed one that has a vacume line running from the engine (mechanical) , it has to be a type with a sensor in the engine bay that sends to the guage (electrical) . but they dont pick that up much . most important thing is its location if its in a head impact area youll fail immedietly . that is usually on top of the dash or pillar guage . behind steering is ok as long as it doesnt block the cluster
make sure your rims and tires match your tire placard, i had all sorts of problems with my 34 when taking it over cause it has 350Z wheels on it but the tire placard said it should only have 17" rims and tires on it, so in the end i had to borrow a set of 17's to take it over as they wouldnt accept the 18" "Z" wheels, then the car was too low cause of the change in wheel size, aaarrrrggggghhhhh!! Make sure no part of the car is lower than 100mm, it was a pain but all good now.
Good luck!!!!
:D :D
The car isl awaiting compliance plates as well - I was under the impression that RAWS is concerned with mechanical mods - not stuff like boost guages/pedals so I wasnt really bothered about RAWS.
Crap - the boost guage is right in the middle of the dash. I'm going to be busy this weekend :hellpisd:
I have a strut brace at the front as well...
oh , you should have said compliancing , that is very different .
the car has to be returned to total stock , rims , exhaust , everything . theoretically . sometimes you get away with things . id find a set of stock pedals , or stock looking ones and remove the guage . less hassle than having to go back again .
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
