Howdy all,
I've just recieved my new happy A'pexi Super Happy Fun Power Funnel airfilter, and I was pondering what I had read in the AFM cleaning thread, whether I should do it or not.
Well, I did it. Here's the pictures for the people who aren't sure.
Here's the old HKS filter pod, dirty as a dog's bum, along with the rest of the engine bay. On the right is the AFM, waiting for the cleaning of a lifetime.
I decided to take the HKS pod and the AFM off in one piece, here on the left, I've undone the hose clamp and wiggled the AFM out... tight fit. There's the sensor data cable, give that tab on the left a really really good squeeze, it should click, and it should pop straight off.
That's the front mesh there, it was utterly black when I got it out, I wiped all the gunk off the front, but I still ran a towel inside it later on. You can see some of the crap inside the afm, and this was after a blast with the contact cleaner
Oh, here's the contact cleaner now, getting to know the AFM on their first date. The large chunks of wood are from an unrelated project. The rear mesh, or remains thereof, is on the right.
The new air pod and the AFM meet, you can see on the right the total reaming of the old mesh area place thingy. That first photo is quite arty, with the ScibyLine just out of focus on the right... I could be a marketing photographer... or... er... maybe not.
The pod and afm move in together, they certainly seem happy together so far, and all their bits fit perfectly. Maybe I'll here the sucky-sucky of little filters in the engine bay soon... and yes, the socket set is a new mod, good for another 30hp at the wheels. With a bit of tweaking on the 12mm socket, the ScibyLine will run 9's. True shit, bro.
Also reset the computer, and it all seems happy. Runs and idles much better, revs much freer down low and I accidentally... well... almost accidentally... okay fine, I dropped the clutch at about 5k and burnt the clutch for the 3rd time. You happy now?? :D
(Cleaning out the AFM seems to not hurt anything and I can see how it would be beneficial. It's part of my servicing now.)
speaking of burning clutches I "accidently" did the same thing and had a horrible smell lingering around for a while....
is this a good thing? im thinking not how much abuse will the standard clutch take...(maybe this should be a new thread) oh well..
Meh, I started the thread, so I'll forgive you...
No, stinky stinks are bad.
In this case, if you give it a bit and it feels like the engine is bellowing but the car ain't moving like it should, or like the wheels might be spinning, but there's no screeching, then the clutch is slipping. You'll get a horrible smell through the aircon. Just buy a new clutch plate because once they start dying, they die faster and faster.
they certainly do!!!
i've just picked up an OS Twin Plate clutch... so hopefully no more slippage.
I'm looking at getting one of those Filters... i don't have an AFM at the moment, running MAP. But as i am in melbourne and there isn't anyone to tune HKS FCON's properly, i'm thinking of changing over to a Power FC and Z32 AFM
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
