Managed to lose 5th & reverse (selector fork?) at the last drag meet as well as my car sounding supercharged in 1st gear (bearing?).
Anyway, what gearbox's are you using/recomend when a standard GTR one wont do?
Its for an R32 GTS-4 with an RB30DET that will be daily driven, and no I'm not made of money so the Holinger is not an option.
https://www.sau.com.au/forums/topic/68784-gearbox-upgrade/
It's only a simple pin broken on the selector rod. It is NOT a sign of gearbox weakness, we get it when the clucth drags (doesn't fully dissengage) and you have to push it to get reverse, enventually it breaks the pin. Replace it and keep using the GTR box until you have enough power and traction to take the teeth off 3rd or 4th gear. Then you have reached the limit of the standard gearbox
The most cost effective upgrade I have found is the Pfitzner (PPG) close ratio dog engagement (replacement) internals for ~$A7K ($US5,500). The Japanese close ratio sets are still synchro and so only provide a marginal improvement. If I remember rightly Theo uses PPG in his 9 second GTR, as well as we use PPG's in the circuit race cars.
www.ppgearbox.com.au
Hope that is of some help:cheers:
https://www.sau.com.au/forums/topic/68784-gearbox-upgrade/#findComment-1276238
Thanks Sydneykid, was hoping you'd see this :)
Im not far of the power needed to break 3rd gear (371awkw) and plan on doing alot more drag racing next season as well as using sticky tyres so prob only a matter of time. I have a spare gtr box now, so i'll repair this one and see how it goes.
Thanks again.
https://www.sau.com.au/forums/topic/68784-gearbox-upgrade/#findComment-1276310
Thanks again.
We are well over 400 rwkw and do many more gearchanges and spend longer in each gear in a 20 minute race than the drag car does in 100 passes. We don't have as much traction though, so you may have a little more headroom left. But I would start saving the pennies now:cheers:
https://www.sau.com.au/forums/topic/68784-gearbox-upgrade/#findComment-1276340
