Intercooler kits imported
Re: Feedback on this kit
I've installed this kit (with the blue piping) on my R33, overall i'm pretty happy with it (for the given price). AFAIK quality of both cooler and piping is excellent, and i have no qualms in offering my recommendation.
A few points
- Timewise, it was about 6 hours to complete.
- You seem to have to cut a significant amount of the fan blades off (definately my biggest concern)
- The R33 SII did not require any cutting or bending of the chassis rails as per the install guide.
- Cutting the hole under the washer bottle is fairly simple, as the metal is thinner than i would have expected and there is plenty of room to move in there with the front bar and inner guard plastic off.
- The cooler fit into existing bolt holes as solid and precise.
- The 2.5" hose clamps are a bastard to work with, i actually resorted to using to original ones off the stock piping
- Bit of a bummer is the std airbox snorkel section no longer fits on past the return pipe, so i have to work out something for that part, probably a cold air feed of some description.
- There is no nipple on the return pipe that u can attach a vacuum tube from to go to the boost control solenoid. That is why the red tube is supplied, to pick up vacuum from another source. I got a brass nipple from auto pro and bolted it into the return pipe basically so i could ensure that i was getting the correct boost "signal" for the boost control/wastegate actuator. Works well no detectable leaks...
All up, i'm pretty happy with the kit especially for that price.
Rob
  • Replies 172
 Share
    • Dropped the car down to my mates shop on the 19th to get it on the dyno. Ran the motor in and dropped the running in oil and filter and filled it up with some engine oil.  Monday arvo I went down and we got a tune in her. Had a fun time trying to get it to hook up on the rollers. We end up having to roll into the throttle, reaching full throttle at around 6k. Made 23psi on gate then tapered off to 20psi up the top and spat out a healthy 700rwhp.  We had a slight voltage issue which was dropping ecu volts to around 11.8v so we called it quits and on Tuesday I went down and ran a couple of new power feeds to the ECU and DBW relays. Have yet to test it as we were trying to get things sent into the ECU from the TCU over CAN. We've now got oil temp, programme switch and gear position. Still working on gearbox speed, but have been told what to do so hopefully that will sort it. Once we've got speed working, we can start setting up the gear shift cuts and do some clutch adaptations in the TCU.  Should have the majority of it setup this week and go over the tune to see how it is now with the new power wire.  Was slack this time, didnt get any full runs as I was watching the TCU data on the laptop. Snapchat-322660241.mp4
    • Not until I googled it, now I remember lol. Seems like it's just to clean it up. But it doesn't stop the leak, I have a leak issue though? Thinking whether I need a new bottle, surely not lol.
    • Ever seen a sock on a PS reservoir in a Jap video and wondered why?
    • Does anyone have issues with their reservoir bottle leaking?? Mine I swear is always leaking from the cap, I realised there is no gasket, are they supposed to have one?
