  • Replies 172
Just fitted the intercooler piping from Raf yesterday. Took me two days cos i didn't have the correct tools and had to source for them. Overall, the piping quality is good but u have to cut away a fair bit of the fan in order for the top pipe to go across the engine without touching the blades. Kind of worried now cos i have consulted a few mechanics and they have all discouraged cutting of fan blades.
Also, the clamps given are useless. No way u could fit them in.....Spend lots of time trying to get them fitted but ended up using the old clamps for my original piping.
Also, i couldn't bolt the piece of metal sticking out to the engine to hold the front pipe in place because i would have to cut even more of the fan blades. so i ended up using cable ties in the meantime before maybe getting someone to make a bracket for me.
By the way i fitted them on a S1 R33 with some help from a guy on the forum.
Babylon....Gimme your email and i will send u the instructions.....Just got the kit fitted on my car yesterday. Seriously the instructions are not much of a help.
Damm i wanted to buy one and do it myself
Is it hard? coz i have no phuken clue what i am doing?
I rang around and the cheapest i found for a pro installing one was $450
[email protected]
Thanks man,
i wouldnt say its hard, id just say it takes some people more time than others. ill post as much info as i can when i get mine.
any word on the arival or is it still sumtime b4 the 6th??
Babylon....Where are u located??? If u are from brisbane try option1garage. Got a quote for $250 to install the kit and trim the front bar to fit before i decided to do it myself. But end up with Jay helping me out most of the time.
ahh shat im from syd dude but thanks anyway :)
That sounds like a nightmare!!!
I have personally installed 3 of these kits on R33's and apart from the clamps all were perfect fits.
With the right tools I am capable of installing them in 2-3 hours depending on how lazy i am.
It is very easy to install these kits.
Cutting the fan blades is a must on even the origional Hybrid Kits which i have also installed and purchased.
Minimal effect and heat difference is noticed.
Consider that the intake temperature is 20 degree's less. :)
So when will they be posted raf?
this might be a stupid question but what did u use to cut the fan blades? can u do it while they are still on the car? anything else you have to cut?
I will ring up tomorrow to try an get a precise date. But I have given customs the documents, the money etc I'm just waiting on th warfies to move there arse.
how to cut: try a coping saw
I always used a grinder to cut the fan blades.
As the blade cuts the plastic the heat leaves the blades nice and smooth and even by melting the plastic off.
update: I talked to customs today they said the ship landed in sydney and will frieght the kits up on the weekend. Monday tuesday I should get the kits. So the very next day I will post them off :)
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
