  • Replies 172
Just fitted the intercooler piping from Raf yesterday. Took me two days cos i didn't have the correct tools and had to source for them. Overall, the piping quality is good but u have to cut away a fair bit of the fan in order for the top pipe to go across the engine without touching the blades. Kind of worried now cos i have consulted a few mechanics and they have all discouraged cutting of fan blades.
Also, the clamps given are useless. No way u could fit them in.....Spend lots of time trying to get them fitted but ended up using the old clamps for my original piping.
Also, i couldn't bolt the piece of metal sticking out to the engine to hold the front pipe in place because i would have to cut even more of the fan blades. so i ended up using cable ties in the meantime before maybe getting someone to make a bracket for me.
By the way i fitted them on a S1 R33 with some help from a guy on the forum.
Babylon....Gimme your email and i will send u the instructions.....Just got the kit fitted on my car yesterday. Seriously the instructions are not much of a help.
Damm i wanted to buy one and do it myself
Is it hard? coz i have no phuken clue what i am doing?
I rang around and the cheapest i found for a pro installing one was $450
[email protected]
Thanks man,
i wouldnt say its hard, id just say it takes some people more time than others. ill post as much info as i can when i get mine.
any word on the arival or is it still sumtime b4 the 6th??
Babylon....Where are u located??? If u are from brisbane try option1garage. Got a quote for $250 to install the kit and trim the front bar to fit before i decided to do it myself. But end up with Jay helping me out most of the time.
ahh shat im from syd dude but thanks anyway :)
That sounds like a nightmare!!!
I have personally installed 3 of these kits on R33's and apart from the clamps all were perfect fits.
With the right tools I am capable of installing them in 2-3 hours depending on how lazy i am.
It is very easy to install these kits.
Cutting the fan blades is a must on even the origional Hybrid Kits which i have also installed and purchased.
Minimal effect and heat difference is noticed.
Consider that the intake temperature is 20 degree's less. :)
So when will they be posted raf?
this might be a stupid question but what did u use to cut the fan blades? can u do it while they are still on the car? anything else you have to cut?
I will ring up tomorrow to try an get a precise date. But I have given customs the documents, the money etc I'm just waiting on th warfies to move there arse.
how to cut: try a coping saw
I always used a grinder to cut the fan blades.
As the blade cuts the plastic the heat leaves the blades nice and smooth and even by melting the plastic off.
update: I talked to customs today they said the ship landed in sydney and will frieght the kits up on the weekend. Monday tuesday I should get the kits. So the very next day I will post them off :)
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring over comms. Everything critical must still be hard wired.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
    • I asked someone about this and he told me about the Audi 1.8T engine. But I think it would be difficult to swap
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
