:werd:
too hard to call on two different motors with different properties
RB25 will be onto around 16psi approx 4200rpm for around 270rwkw for a stock headed RB25, you'll be pushing the upper limit of the turb for 310rwkw
is it a 6 blade or a 7 blade wheel?
Engine model 	 1JZ-GTE 	 RB25DET
Displacement  2491    2498
Max.power (Net),  205.94 kw / 6200 rpm  183.88 kw / 6400 rpm
Max.torque(Net),  362.85 Nm / 4800 rpm  294.20 Nm / 4800 rpm
Compression ratio  8.5    9
Bore, mm 	 86    86
Stroke, mm 	 71.5    71.7
Well in stock guise the 1JZ is the more powerful motor by a reasonable margin, but slap the same turbo setup on them and the RB25 might just pull away since it has the higher compression ratio, but how about your friends stop comparing penis sizes and get on and fit the turbos so we can all see the results! :rofl:
