I don't have a print out of boost & power vs speed, so can't answer that question.  I would be guessing that the stockers are pretty much on the limit at or around 250rwkW in terms of airflow...
What sort of improvement could I expect with N1s? 2530s? GT-SS?
We get pretty close to 300 4wkw with the R34 N1's (ball bearing). But that is with a standard (blue printed) N1 RB26DETT. Probably another 50 or so with cams, intercooler, head work etc.
Love those 2530's, 385 4wkw is the best I have seen. Build boost almost as fast as the R34 N1's. My favourite all round turbos for a 2.6 litre.
GT-SS's seem to do a little better than the old 2510's, so around 325 4wkw. I heard 600bhp made 365 4wkw with GTSS's, his engine is extensivley modified though.
Hope that helps:cheers:
What power do you guys think i can make with 32 series 2 n1's power fc zorst 34 n1 cooler dumps pods and so on
i was thinking next step of cam gears and cams,
but i didnt know just cam gears on their own made a difference what should i expect from just cam gears thought u could not play with standard cams
