Guys;
I've had my gearbox rebuilt (was catching on 1-2 too often) with new synchros and bearings and I'm running Motul oil. Problem is that it still sometimes catches 1-2 and 2-3, doesn't matter whether it's cold, hot, hi rpm or low rpm. Only way to guarantee it won't catch is to pause briefly during the shift but that means losing pace. 3-4, 4-3, 3-2 are no problem.
Tried different oil and Slick 50 but no change. I know that heavy duty (compared to most other cars) gearboxes like the GTR tend to be a bit clunky due to the sheer size etc of the internals and I don't expect it to be ever be as smooth as a Camry or WRX ie 'hot knife through butter, but I'm not happy about this happening in mine so soon after a rebuld. It doesn't get thrashed and I expected that the shift might be heavy but still smooth with no catching - ever. Rebuild was done by Award in Sydney.
Is this just the way they are or should a rebuilt box be like silk? Thanks for any feedback.
Regards
https://www.sau.com.au/forums/topic/68896-gearbox-shift-quality-r32-gtr/
A couple of things come to mind.
Firstly, make sure the clutch is not dragging.
Secondly, the viscosity of the oil in your box will make a big difference to the shift quality & to the synchro's. First stop is to make sure you have the right grade.
The second step is to use the ubiquitous Redline oil. This often helps old/tired boxes, but I'm not sure about new ones.
Beyond that it may require the gearbox out again.
Just out of interest in regards to viscosity.. too viscous means you tend to drag stuff right? and if it's too thin what happens then?
I've been running redline shockproof heavy in my box and now it's seized in 3rd so I'm wondering if that may have done it?
Too thin means Crunch!
Guys;
Regards
Mmmmmm, gearboxes do take time to run in and you haven't mentioned how many K's it done since the gearbox was rebuilt. Personally i don't find GTR gearboxes to be overly heavy or slow to shift. We use exclusively Castrol synthetic lubricants (Syntrax 75W90 in the gearbox) so I have no experience with other oils.
If it were me, I would have a talk to Award and see what they have to say:cheers:
Thanks SK;
It's probably done about 6000km since the rebuild. I'll talk to them, have already spoken to the shop that took it out and they were full of words like 'size of internal parts, mass, old technology' etc but they didn't give me a definitive answer.
In particular I don't see why it would do it sometimes and not others.
Regards
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
