I'm sure there's been a thread on this before somewhere, but I can't seem to find it.
I know that the PowerFC Pro has some sort of launch control, but is there anything else that it has over the regular PowerFC?
Is it worth paying the extra to get the Pro?
Just that I'm about to order one of the two, and the Pro is considerably more expensive by the time you factor in the cost of the hand controller.
Cheers :)
https://www.sau.com.au/forums/topic/68899-powerfc-vs-powerfc-pro/
it has two rev limiters one for when the cars wheels are not turning and one for when the car is moving.ie on the drag strip and your at the line.when you have the throttle flat you can set the limit to say 7500 for getting of the line and once your moving you could set it back up to 9000.
Hey all...
The Differences between the PRO and the Normal FC...
1) Launch Control
2) Cuts The Ignition instead of Fuel (normal FC) at The Rev Limiter
There are 2 kinds of PRO Versions...Detro one eliminates the AFM's and replaces them with MAP sensors...
The other keeps the AFM's but has the 2 extra options...
Im Running the PRO Detro version
Hope that helps...
cheers
Tony
Dude,
I know your after the bling factor of launch control.
You can always add this later. I'm fitting an external sort of device which is launch control. Can use it with stocker ecu etc. Just a sequential ignition cut I'm pretty sure.
Hey Dan
Yeh but I don't want to use the stock ecu because I'm using bigger injectors etc.
Also like the functionality of the PowerFC.
But it's all good because I have now ordered the PowerFC Pro :)
Cheers for the replies guys :)
The question is though for most ppl. How important is the ignition cut over a fuel cut as most aftermarket ecu's use a fuel cut.
Exactly. I'd like to know this also.
What I can't understand is that why have Apexi changed the cut? E.g A stocker gtr ecu uses ign cut, whereas if you change to the regular FC, it uses a fuel cut. Odd.
What are you going with simon? Still going Wolf or what? Wolf use ign or fuel cut?
James,
What I meant by that is that you can have a PowerFC, Microtec like eggy/dave, or whatever etc and add this external device and still get launch control.
Now that you've bought the FC Pro.....go and buy the software from nengun. $300-$400 del I think.
Yeah I knew what you meant but there's no point in having all this extra external crap when you can buy one unit with the lot included !
maybe, just a crazy idea in my head, but the issues with cutting fuel in hi-po engines may have lead the pro version to cut ignition instead
or a more simple and uderstandable way of explaining is - ppl who want pro must have a high grade engine, therefore better to make it cut ignition then risk engines due to lack of fuel at high revs....
