I'm sure there's been a thread on this before somewhere, but I can't seem to find it.
I know that the PowerFC Pro has some sort of launch control, but is there anything else that it has over the regular PowerFC?
Is it worth paying the extra to get the Pro?
Just that I'm about to order one of the two, and the Pro is considerably more expensive by the time you factor in the cost of the hand controller.
Cheers :)
https://www.sau.com.au/forums/topic/68899-powerfc-vs-powerfc-pro/
it has two rev limiters one for when the cars wheels are not turning and one for when the car is moving.ie on the drag strip and your at the line.when you have the throttle flat you can set the limit to say 7500 for getting of the line and once your moving you could set it back up to 9000.
Hey all...
The Differences between the PRO and the Normal FC...
1) Launch Control
2) Cuts The Ignition instead of Fuel (normal FC) at The Rev Limiter
There are 2 kinds of PRO Versions...Detro one eliminates the AFM's and replaces them with MAP sensors...
The other keeps the AFM's but has the 2 extra options...
Im Running the PRO Detro version
Hope that helps...
cheers
Tony
Dude,
I know your after the bling factor of launch control.
You can always add this later. I'm fitting an external sort of device which is launch control. Can use it with stocker ecu etc. Just a sequential ignition cut I'm pretty sure.
Hey Dan
Yeh but I don't want to use the stock ecu because I'm using bigger injectors etc.
Also like the functionality of the PowerFC.
But it's all good because I have now ordered the PowerFC Pro :)
Cheers for the replies guys :)
The question is though for most ppl. How important is the ignition cut over a fuel cut as most aftermarket ecu's use a fuel cut.
Exactly. I'd like to know this also.
What I can't understand is that why have Apexi changed the cut? E.g A stocker gtr ecu uses ign cut, whereas if you change to the regular FC, it uses a fuel cut. Odd.
What are you going with simon? Still going Wolf or what? Wolf use ign or fuel cut?
James,
What I meant by that is that you can have a PowerFC, Microtec like eggy/dave, or whatever etc and add this external device and still get launch control.
Now that you've bought the FC Pro.....go and buy the software from nengun. $300-$400 del I think.
Yeah I knew what you meant but there's no point in having all this extra external crap when you can buy one unit with the lot included !
maybe, just a crazy idea in my head, but the issues with cutting fuel in hi-po engines may have lead the pro version to cut ignition instead
or a more simple and uderstandable way of explaining is - ppl who want pro must have a high grade engine, therefore better to make it cut ignition then risk engines due to lack of fuel at high revs....
    • If it's for a SR20, make sure it's not the American Poncams, might as well call them Poocams. Had a set in a friend's car, all scuffed up after a few track days. Like the metallurgy Tomei USA used is junk. Went back to JDM OG Tomei Poncams, no issues till now.   Tomei USA is not the real OG Tomei.   Random rant over, fk the US of A, bunch of c u n t s.
    • Most of the industry in North America either runs on Siemens or Allen Bradley. I have two redundant S7-1500's on my desk right next to me for simulation. Siemens has been losing ground though since Stuxnet, as cybersecurity is a big thing. In my line of work that is federally regulated, you must by law have a cybersecurity management program in place and its audited and inspected every so often.  I work with Emerson PLC's daily (RX3i's) and have done large biogas/refinery projects with their DCS's. Their PLC's are somewhat OK minus the way they do PLC redundancy (You have to download on both PLC's separately every time you make a change )  As for their DCS's... you'll be limited financially first before anything else stops you. Costs are exorbiant at roughly 10x what it would cost you to do with any other system (e.g AB PAC).  1990's, those suckers are brand new haha! Kraft-Heinz (An old client when I use to work for an ESP) still runs Siemens TI505 PLC's from the mid 80's. Ohh how I don't miss working with those... you could only do a certain number of online downloads until it's "Change" buffer would be full and you would then need to go offline to do a full download. There was no warning of when this was coming up and it generally would happen when you would go in at 2am to make changes before production -_-.
    • Unfortunately, not only is that not the case, one of the main "Selling points" of safety over comms is they clearly state in writing that there's no need to segregate safety networks from non-safety networks. It always gets intermingled with everything else on an ICS/OT network.
    • Hello. I have an a31 cefiro but since I am in Turkey we have a CA20S engine. I did some research. Then I found that I can swap with a ca18 but when I heard that it has the similar substructure as the s13. I thought I can swap with an sr20 because the sr20 was used with the s13. So can I easily swap the sr20 on my cefiro or is it difficult?
