Ok now i havnt trolled through a search to see if anyone else has suggested this yet, but i do remember a lot of people asking about this.
I was thinking about the nissan engine naming system the other night while a tad bored and this is what i've come up with, if anyone knows better please correct me.
Now as we all know the SR is a 4 cylinder alloy block, and the RB is an Iron 6.
Now the japanese word for "4" is "Si" and the jap for 6 is "Roku", to me this is a pretty obvious pointer. SR must mean "4 - somethingorother" and RB "6 - somethingelse".
Now can anyone tell me if there is a japanese word for Alloy or aluminium that begins with an R or a word for iron that starts with a B?
Any takers?
https://www.sau.com.au/forums/topic/68912-is-this-the-meaning-to-rb-and-sr/
  • Replies 40
japanese slang for alloy is "alu" if that helps.
something that dosen't sit right with that theory is the fact that FJ20's and CA18's are all 4 cylinders and they have different characters, same with the older L series straight 6's.
One of the guys suggested that R was for Rong (japanese dosen't have an L in katakana, hence Long is pronounced Rong) and S was for Short :) I think we threw something at him for that stroke of brilliance.
Good theory though, sounds a lot better than the nut-jobs that think RB stands for Race-bred.
cheers funky..... well the good news is that the FJ and CA thing doesnt go totally against what i've said.... but instead just throws any hope of consistency to use as a lead... bugger :)
I hope you threw something heavy at him :)
do we have any other takers with theories on these that ARENT "Race Bred" or related.
Guys I wouldn't waste too much time trying to figure out why Nissan used 'RB'26 or whatever... I noticed that most of the guys who do seem to think the Japanese people think in English, thereby we have numbskulls sayin "RB means 'race Bred' uleh!"... LOL as if the Japanese would do that.
But one little hint as to what they did mean, the R31 Skyline range included the '2.8D GT Passage D' which obviously was powered by the 'RD28' diesel engine. So if we look at that designation, the 'D' in 'RD28' means diesel of course... obviously... nothing groundbreaking there. Hmmm, I'd go as far to say that the first letter ie: 'R' in 'RB26' is just a letter used to signify a petrol inline six.
its like asking what is 'pH' stands for?!
pH? why that stands for pH = -log10[H+] which is the "hydrogen ion exponent" and the designation PH for the numerical value of the exponents of this power.
[H+] indicates the activity of H+ ions (also written [H3O+], the equivalent hydronium ions), measured in moles per litre (also known as molarity).
why do u ask? :rofl:
maybe you should have trolled through search..
you would have found this..
R = 6 cylinder, closed deck.
B = Gasoline application using cast iron/nickle based block.
S = 4 cylinder, closed deck.
R= Gasoline application using sand-cast alloy based block.
K = 4 cylinder, closed deck.
A = Gaslone application using sand-cast iron based block.
Q = 4 cylinder, open deck.
R = Gaslone applcation using die-cast alloy based block.
nah the RB26 is a RB26
yeh im not trying to say they are the same engine but they are built the same just with 2 cyl + or -. Solid lifters and all that jazz. Plus whats 18x1.5?? thats right. 2.6 and change. Testament to the fact that my ca ownz :rofl:
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
