  • Replies 40
Maybe once this mystery is solved we can research the meaning behind Toyota and Mitsubishi's engines, anyone hazzard a guess at what 1JZGTE or 4G63 stand for? :)
Have a look here for toyota ones http://www.toymods.org.au/tech.html
RB = Rough Bastard ?????
RB = Rude Bitch/Bastard ?????
& just for you Messiah, doesn't pH stand for percent Hydrogen ?????
how can a scale that starts at 1 and goes to 14 be a percentage? :(
Nah just to clarify pH, when a fluid is "ionized" it breaks off into negative and positive Ions. Water produces roughly equal ammounts of neg/pos ions and hence is neutral. Things like HCL (Hydrochloric acid) give out more positive ions than negative.... or was that the other way around.... but due to this its an acid
but u get the drift.
I find it comical that there are several sites that endulge in the whole Race Breed thing.
All I can say is RB20E.... & the diesel RB28.... NOT what I'd call race breed personally.
dont forget the good old rb30e! :)
Racooo Breeedoooo!!11!
68kW/170Nm of track-tearing performance fitted to the equally apex-hugging NQ Patrol.
Although, admittedly this is actually an RD28 due to it being diesel rather than petty powered... :(
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
