Just out of curiosity, is 380 kms with a tank(60Litres), bad?
mixed city and highway (decent) driving, no major mods.
Could it be better? if so.. how? and don't say, don't drive a skyline :)
That is almost 16L/100Kms for a 2.6L car :)
Im just not very happy with it, and wanted to see if you guys out there are in the same situation.
Cheers.
https://www.sau.com.au/forums/topic/68916-petrol-consumption-r33-gtst/
you say your talking about an r33 gtst with no major mods.
so how is it a 2.6L????
anyways, i get around 450l per tank, which i am pretty happy with, i end up with a 11L/100Km's average, but thats when i drive around changing before 2500rpm.
i do also give it a hit at least once each time i drive the car.
Hmmm...I was just about to put up a similar post Ricoh :)
I've been battling the whole fuel consumption thing for a while...like most of us. My set up is relatively mild: 3" front/dump, 3" HF Cat, 3" Kakimoto at the tail, Trust Pod.
Last weekend, I put in a new O2 sensor which seems to have helped a bit (There are many threads about this by the way). I was getting 350Ks max from a tank (Running on/off boost...it didn't matter) but so far I have got about 120kms from 1/4 tank (BP Ultimate)...do the math...hoping for 480ks a tank. This is an obvious improvement so I recommend fitting a new one (O2 sensors only last 40000Ks, when they go kaputt, the ECU runs rich by default). I fitted an EL Falcon O2 sensor which cost me $86 from Motor Traders (A hell of a lot cheaper than the $180 Nissan Genuine part). The only catch is that you will have to cut and re-wire it to fit the Nissan connection...No big deal, the colour of the wires are identical. I can give pics if you want them.
I also cleaned the AFM with some contact cleaner that you can buy from Dick Smith. I am using a Trust Airinx pod but I need to partition it to eliminate some of the hot air. This should help the efficiency a bit as well. NGK Platinums are also a good investment.
Always remember the obvious: Tire pressures/alignment, oil viscocities (Not kidding), fuel filter, type of fuel, injector cleaner.
At the moment, things are looking promising, even if I squirt her a little just to make my presence heard :)
By the way, I would never tell you to "Not drive a Skyline" :) I would rather pay an extra $20 a week on fuel than drive a tryhard OZ performance POS :)
Remember, she's quite a heavy, well built car so heavy fuel consumption is a trade off. Luckily we don't have to rev the Sky's tits of to get some performance out of them...it would be even worse then.
Pics would be good mate!, Ill give that a go and see if it works for me. Thanks
I had a once off distance of 650km to a tank.
I was driving on the space saver spare wheel for half of it (had a flat in sydney, drove to newcastle and back on it before I could get the tyre repaired).
So half was normal commuting, the other half was freeway driving at 80-90kph.
Cheers Terry M. and btw you wouldn't offend me by giving me more info since my knowledge level when it comes to all of this is very limited.....to say the least :D
Now, I have another issue that I havent even noticed before.... every week regardless of how much petrol a have left in the tank I fill it up again...now, the first 200 k's ,the petrol gauge doesn't move at all, then it starts moving down slowly past the full tank line and then...you can almost see it go down as you drive, it almost goes down 3 1/4 of a tank in 80 to 100 k's. weird. anyone with the same problem.? or anyone know why this could be happening?
Thanks guys!!
I have the same problem, the guage is all over the shop after 60Ks from filling up. I wouldn't be too concerned. I resist the temptation to look at the guage until I get home and I'm on my level driveway, then I get an accurate reading.
It seems to vary heaps depending on road level...stupid pedantic thing.
If I can help with anything mate, feel free to PM me...I've been around Sky's for a while now ;)
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
