While we're comparing T88 powered cars and blow arsing how bad big singles are why don't we chuck in Theo Wolletts T88 powered GTR or are his times to quick to mention?? :P
or Glen Sucklings T51r powered GTR in NZ what did it run its fisrt time out ?? I think it was a 8 second pass a touch better the mid 11's
  • Replies 96
Guest two.06l
not doing that at all bu5ter...just know what car/cars Ben is comparing his to and its not a fair comparison. he should be comparing it to the likes of the cars you mentioned....instead of half arsed examples.
Guest two.06l
not doing that at all bu5ter...just know what car/cars Ben is comparing his to and its not a fair comparison. he should be comparing it to the likes of the cars you mentioned....instead of half arsed examples that i myself have seen at croydons. Just because it has a T88 Ben doesn't mean it is a well sorted car.
It's not so much if the gears are straight cut or helical, true helical are quieter but they both use direct dog teeth to engage the gears. There's no buffer zone, and with a seq you can't exactly rev match on the downchange - which is one of the big destroyers of dog teeth.
hahaha its only a poor old GTST, rwd and all can't expect to much ... and to make matters worse the driver weighs 108kg
And that bodykit you got from mainland China was made out of Bamboo, and weighs in at a hefty 110kg too!
Not to mention the 5mm thick exhaust, and then the 75mm thick intercooler.
hahahah
Hi guys i didn't mean for this to get out of control with the comparison of the toque figures.
as for the gear box i didn't know the Abflug made.one i was comparing to a freinds Hollinger which is noisy.and not that great to drive around the streets.
also the hollinger ia rated at 700hp were as the OS is rated at 1200hp.
i didn't mean for this thread to get all nasty.
just that the car has lots of torque that's all.
anyway were are looking foward to getting back to the track not this but next.
Cheers Ben
Cheers Ben
Love your work good to see you're not wasting any time with this project :P
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
