hi next car im pretty set on a r32 for now and got a few Q's want to get one as cheap as possible but would prefer to pay more for a better condition one thought bout gettin an auto and doing a conversion or even gettin a non turbo from and doin a conversion as yahoo sell them around 4500 how hard would this be to do and have it all legal??or would it be easier to just buy an r33
i also want to make at least 225rwkw car will be used for street only just for my fun so reliability must be kept also so far ive got the list to do as 3inch zorst, 13bt rotor injectors, fmic (gtr maybe) bosch pump, what turbo to use and what computor say gredy emanage do or have to got to apex pfc??
i want to keep car legal as possible and only do it up performance wise mainly for some fun for a few yrswhile i get a house so its not somethin i need to go spending big dollers on sopnething i dont really need
any help would be great cheers
this in the right section???
https://www.sau.com.au/forums/topic/68947-32-help-please/
Hey mate - there is only one way you are going to be able to import your own R32 and that is through one of the brokers who haev already bought cars and they are 'in stock'. DOTARS have effictivly stopped the 15yr old rule.
I would suggest that you look locally at the R32's and the R33's that are available. Try www.carsales.com, I was looking there yesterday and there is 9 pages of cars :headspin: Follow these rules
1. get a manual, don't look for a cheap auto to convert ($$$)
2. Stick to your purchasing budget (most of the good manual R33's seemed to average about $17k+)
3. get an apexi PFC - they can be had for $1000 now!!!
4. get new injectors that suit your car, someone on the forums got reconditioned and hiflowed units fromthe states for ~$500. you might get new Sard units for $650 ~600cc
5. get a 3 or 3.5 inch exhaust from the turbo back (you can get these S/H from your friends on the forums). Note - most systems are from the cat back
6. get a decent cat (not a generic hi-flow), I use an Andretti magnaflow 3in (from the US).
7. get a HKS 2540, or GT-RS turbo (you might be lucky enough to find one S/H from here)
8. bosch 044 pump (again - seek the forums)
9. hybrid front mount intercooler (cheaper than the GTR unit) yawn - forums...
10. enjoy your easy 250rwkw on low boost....
If you are a smarty shopper, you may be able to pick up a modded example, but be VERY careful that it is modded right - get someone from a shop that knows skylines to check it out. The $150 - $200 you spend could save you a lot of time, worry and money.
if you need to know anything else, PM me as I rarely get in this section.
Cheers
https://www.sau.com.au/forums/topic/68947-32-help-please/#findComment-1285603
mate...200rwkw is plenty on the streets....if it's for street use only I'd recommend a higher average power rather than a high power at one rpm point (I remember SydneyKid saying something like that). 225rwkw on a RB20 is laggy...
IF you're gonna do a conversion make sure you get some more cubes. RB25 or RB30...
https://www.sau.com.au/forums/topic/68947-32-help-please/#findComment-1285635
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
