  • Replies 48
we here at SAU don't condone that sort of behaviour anyhow
I dont know who you are, but you shouldn't be speaking on behalf of SAU. If that was true this thread would have been closed, before it was even posted.
if you wanna do that stuff go to nissansilvia.com with all the other little boy drifters!
What's the point in saying that anyway, you are old enough to realize what the outcome of that post was going to be. provoking a 20 yr old!
Look I am not on anyones side here, I just think that if people are not interested in the subject discussed on this thread, they should refrain from posting on it.
Cheers.
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1288831
Richo,
Your origional post was fine.
something like a Skid Pan even if you have to pay to get in..
PM me for details or addresses we dont want to bring too much attention :)
I think frogstomp31 tends to skim read, hence why he posted locations instead of PM'ing you.
I'm cleaning up this thread now.
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1288861
i have try search information of tailem bend race track but no much info come up
and as other event organizing in SAU, 1/2 will not coming
i rather join the event other club organizing
less hassle
http://users.tpg.com.au/heliguy/Events.htm
found this, anyone interest at the Motorkhana Practice Day this sun?
i will try to ring them tomorrow moring
hope they can organize me a CAMS lic b4 the event
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1295984
they should have temp license avalible for $20-30 one day. all the events i have been in that are done with CAM's have had the one day option. ill ask Nissan Datsun Car Club about the mitsu track at tailem, i used to be a member and we had an event there once.
the events at lonsdale are very fun, i used to goto everyone of em until they became extreemly popular and we ended up waiting for an hour between turns, which is shit when you consider your on the course for less than 2min at a time.
:fart:
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1296020
The event at Talem Bend on the weekend was organised through the rotor club. My mate goes to all the meetings etc. i'll try and find out a name/number, no garuntees tho. Saw a video of the event just yesturday. they ran a motorcana thingy. I'm not sure of the extent of the facilities there, ie. how much road they have, but they definaly have a skid pan.
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1296077
my s15 is a second car, and i don't drive it much really.
to make sure i am not buying a car to sit in the garage,
i want to attend as much sport event as i can, maybe a full year cam lic will works out much cheaper for me
they do mention a "L2s" lic, which is under $100 per year
do u know much detail of it?
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1296083
ring them up today
and they can oragnise CAMS licence on the spot :D
entre fee : $20
CAM lic
1 day pass is $20
year pass is $46
L2S is $8x
time: 11:00am
for those who don't have a cam lic pls arrive at least 1/2 hr earlier
hope to see some SAU member there
https://www.sau.com.au/forums/topic/68989-skid-pans/page/2/#findComment-1303007
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
