Hi all,
Car for sale, due to great responds by time wasters, i've decided to stay until the car have been sold.
spec as below:
car: 1988 A31 Nissan Cefiro 4 door sedan DarkBlue with side skirts, newer model tail lights.
specs: rb20det manual ( was auto but converted to manual in japan)
apexi airfilter, rb25det blow off valve, full exhaust system, front and backTein coilovers, 15inch ssr rims with rear rims wider offset. Momo steering wheel, boost meter,exhaust n engine temp meters ( unfitted) radio, aircon and other electrics luxurys.Car runs wells,
SOLDSOLDSOLD
THANKS SKYLINE AUSTRALIA..
japcrp,
yes it is, plus to send a car outside WA would cost around $500 depending company..thanks
i would drive it back! yea baby.
or atlest to sa then the train.
i am trying to sell my car at the momet so i will not waste you time but i am realy intrusted!
thanks
    • Are you suggesting that the kit did a cheap and nasty job of just jamming the wheel in between other things and caused the misalignment? I mean, we normally do this with an integrated crank trigger wheel, not something bodged on. It's not 1995 any more.
    • I mean, given the number of BMWs you own their tolerance for improper torque is rather low. The number of torque + angle spec bolts and non-reusable bolts in one is nuts.
    • Atmospheric vent requires something that doesn't use a MAF for load. You would need a standalone ECU for that.
    • Hey all,   I’ve got an RB25 with a trigger kit that includes a crank wheel, and I’ve hit a wall trying to sort a timing belt tracking issue. The belt either rides right on the edge of the cam/crank pulleys or walks slightly forward once the engine starts. It tracks okay-ish for a moment, then creeps right to the edge—and honestly, it’s stressing me out.   I’ve spent hours removing and reinstalling the belt, double-checking everything:   Tensioner setup is good, checked multiple times Idler pulley and washers are all in the correct places Followed the RB25 timing procedure step-by-step     The only thing I changed was the rear crank washer—I swapped the OEM one for a Neato version, and it made things worse. The belt now sits even more forward than before. I’m beginning to think the crank trigger wheel itself (from the trigger kit) is the issue—poor design or slightly off dimensions.   What’s strange is that with the previous belt setup, it actually ran fine for a couple of years—around 4,000 to 5,000 miles, even with hard driving and high RPMs. But even then, the belt was always riding right on the edge, and I know that’s not ideal or safe long term.   At this point, I’m debating whether to:   Machine a few mm off the crank trigger wheel to bring it back in line, or Replace it entirely with a better-designed unit     Only thing is, I already have the Cherry Hall sensors, bracket, etc.—I just want to replace the wheel only, not the entire kit. Anyone know a brand or supplier that sells just the crank trigger wheel on its own?   Would really appreciate any feedback—especially from anyone who’s run into this exact issue and found a reliable fix.   Thanks in advance.
    • Hi...a little refresh. Is Nistune gonna be enough to run BoV? Or do i need some proper ECU?
