Hay guys i have been talking to afew poeple =) about cars more towards imports.
afew guys i was talking to say that you can bend the chassis just by hitting a gutter etc. =)
and they were saying that when u buy a car from japan even if they say it hasnt had any accidents there no way of the inspectors or whoever is there to tell if its been cut and shut chassis damage etc =)
now i wanted to ask you guys how bad is this stuff.
if your chassis has been damaged. not talking about hitting a poll or whatever if its in an accident etc
if they were to straghten it back up will your car be the same?
handle to same drive the same etc =)
tell me your thoughts hehe
https://www.sau.com.au/forums/topic/6901-chassis-damage/
if u get a wheel alignment done front and back before you buy the car they can tell there and then if the car is bent!
this is what i was told anyways....and ours checked out alright
btw...you dont want a car with a bent chassis, it will handle like shit and when you brake, the car will pull to one side....you can also tell if the car turns better in one direction than another.
also...check the subframes which hold the suspension, this can also cause the problems listed above...
hope this helps in some way
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102100
Or just buy your skyline from a reputable importer not a dogy backyard guy.
The auctions in japan use xray analysis on the chassis which indicates when a car has been repaired. The results are evident in the auction grade of the car in question
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102272
I found a little while ago that one of the chassis (?) rails was a bit crushed and one of my sills has a dent in it, I think this may have happened a one of the services I've had....
The car still drives good and nothing was mentioned when I upgraded the shocks and wheel alignments have been done with no problems. I think someone would have said it needed fixing if it was a problem..
Don't know if this is the sort of info you were after??
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102320
Originally posted by hippy
boosted?? so i think i might have that problem ... what can i do to rectify it?? that is the problem with the shitty handling and steering problem as well as the car pulling to one side when braking.
My 180sx had wheel adjustment problems. I couldnt get the camber on the left straight at all. Finally a friend discovered the car had a bent chassis and they never straighten it up properly.
I took it to a friend who fixed it beautifully.
Bent chassis arent that bad. Anything these days is fixable. Its up to you if you are the worrying type. Better off as Nick says going to a reputable importer. But if you dont mind things like that then it isnt that bad.
Needless to say but the 180sx was perfect after that.
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102509
so how do i go about fixing it?? who can i get to do it for me and what does this kind of work involve?? cause i 've had an accident with the car already ... so that could of made it worse ...
A reputable smash repairer.
Trust me they know and can fix it, its their job.
All the best my friend
Minh
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102540
Guest LoudBlueBMW
If there is damage to the chassis and it is corrected properly then by all means it should steer, handle, etc as well as before, but keep in mind the properties of metal and how if you bend it one way then another it will weaken it somewhat. Correcting minor damage shouldn't really pose a problem, but if the car has had major accident repair, think about the next time the car cops a hit, will the driver be so lucky? That's why a lot of people that have accidents in cars and get them repaired will sell the cars afterwards.
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-103222
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
