Hay guys i have been talking to afew poeple =) about cars more towards imports.
afew guys i was talking to say that you can bend the chassis just by hitting a gutter etc. =)
and they were saying that when u buy a car from japan even if they say it hasnt had any accidents there no way of the inspectors or whoever is there to tell if its been cut and shut chassis damage etc =)
now i wanted to ask you guys how bad is this stuff.
if your chassis has been damaged. not talking about hitting a poll or whatever if its in an accident etc
if they were to straghten it back up will your car be the same?
handle to same drive the same etc =)
tell me your thoughts hehe
https://www.sau.com.au/forums/topic/6901-chassis-damage/
if u get a wheel alignment done front and back before you buy the car they can tell there and then if the car is bent!
this is what i was told anyways....and ours checked out alright
btw...you dont want a car with a bent chassis, it will handle like shit and when you brake, the car will pull to one side....you can also tell if the car turns better in one direction than another.
also...check the subframes which hold the suspension, this can also cause the problems listed above...
hope this helps in some way
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102100
Or just buy your skyline from a reputable importer not a dogy backyard guy.
The auctions in japan use xray analysis on the chassis which indicates when a car has been repaired. The results are evident in the auction grade of the car in question
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102272
I found a little while ago that one of the chassis (?) rails was a bit crushed and one of my sills has a dent in it, I think this may have happened a one of the services I've had....
The car still drives good and nothing was mentioned when I upgraded the shocks and wheel alignments have been done with no problems. I think someone would have said it needed fixing if it was a problem..
Don't know if this is the sort of info you were after??
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102320
Originally posted by hippy
boosted?? so i think i might have that problem ... what can i do to rectify it?? that is the problem with the shitty handling and steering problem as well as the car pulling to one side when braking.
My 180sx had wheel adjustment problems. I couldnt get the camber on the left straight at all. Finally a friend discovered the car had a bent chassis and they never straighten it up properly.
I took it to a friend who fixed it beautifully.
Bent chassis arent that bad. Anything these days is fixable. Its up to you if you are the worrying type. Better off as Nick says going to a reputable importer. But if you dont mind things like that then it isnt that bad.
Needless to say but the 180sx was perfect after that.
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102509
so how do i go about fixing it?? who can i get to do it for me and what does this kind of work involve?? cause i 've had an accident with the car already ... so that could of made it worse ...
A reputable smash repairer.
Trust me they know and can fix it, its their job.
All the best my friend
Minh
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-102540
Guest LoudBlueBMW
If there is damage to the chassis and it is corrected properly then by all means it should steer, handle, etc as well as before, but keep in mind the properties of metal and how if you bend it one way then another it will weaken it somewhat. Correcting minor damage shouldn't really pose a problem, but if the car has had major accident repair, think about the next time the car cops a hit, will the driver be so lucky? That's why a lot of people that have accidents in cars and get them repaired will sell the cars afterwards.
https://www.sau.com.au/forums/topic/6901-chassis-damage/#findComment-103222
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
