yeah i was thining that about the 700cc but i want to find some second handm just depends what is avalible,
and car is not standard got n1's 4" zorst ,34 n1 cooler, dump's, pods all the usualy stuff
made 389 hp on 10psi untuned
so on 20psi tuned should be making some serious power (FOR ME)
