I've just got my silvia on the road today and am making sure nothings wrong before i really start to drive it.
I know the hallmarks of a 1.5/2 way diff are noise going round corners at low speed but i've got very pronounced noise and clunking around corners and going straight at low speeds. Its most noticeable rolling at low speeds then engaging/disengaging the clutch with a little bit of throttle. The clunk is enough to be felt throughout the car and my seat. I would expect the car to have a mech diff as its fully set up for drift.
Fully stripped interior/boot and drift suspension setup are obviously going to increase the noise and vibration, but is this level of 'clunking' normal?
Diff pictured below (non-standard rear cover?).
https://www.sau.com.au/forums/topic/69046-mega-clunking-from-rear-2-way-diff/
i have a clunking sound too... its a very light and not too deep.
similar conditions to yours, mine can only be heard during slow turns or slowly applything the
throttle.
BUT - i think i have a standard LSD, i have spoken to my mates and they have heard it too..
they reckon its NOT the diff, and more possibly the exhaust (stock) which may have worked
itself loose or something.
I notice no difference in how the car handles however... does this sound like your problem?
i'd be interested to hear what others think?
I had a 2 way in my silvia and only on cornering did it make noises, hell noises too. You could also feel the car shift sideways on itself after correcting. Not sliding either, normal driving.
I would think there is some problem with the tailshaft/diff connection if its clunking under on off throttle.
Mine is a deep 'mechanical' sound. The exhaust is attached very firmly, there is slight grinding noise due to working the surface rust off my brake rotors, and the boot rattles round a bit, but this can clearly be heard over the top.
Yeah, that's what it feels like.
My old standard diff in the 180 made clunking noises on/off the clutch at low speeds too due to the button clutch sending shock through the tailshaft.
that's normal then! Its all good :) Price you pay for sideways on demand..... :)
All rear drive cars have some degree of driveline slack, what you mentioned is just the normal behaviour of hardcore 2 way... amplified by the stripping you've done.
Don't forget you almost sit over the diff in an S13 if your fairly tall...
My brother's car is the same, shuddering and noises is pretty bad during low speed cornering. Was recommended to do a rebuild of the diff, with new clutch plates and all. About $600 for our 1.5 way.
I has my Kaaz two way rebuilt by this knob in Fyshwick and he put it back togeather wrong with incorrect clearances and preloads etc.
The result felt like someone was swinging a sledge hammer under my car when i turned even the slightests corner witth anything less than heavy throttle.
Even coasting into a corner in 4th or 5th would get it going.
The car dramatically changed direction between on and off throttle two.
Since having it rebulit by a decent engineer, it is perfectly smooth when driving around town under normal throttle.
If you try and do a hill start and turn at the same time it will carry on a bit until the clutch is fully out. Then it just locks up nicely and skips the inside wheel a bit.
Running a decent synthetic oil can help but over time they can loose the correct preload settings and clearances due to normal wear and tear so yours could be half way to were mine was.
My Nismo GT Pro 2 way is very clunky at low speeds ie 5kms or less. Its currently set to the softest setting, and yes its damn clunky when the clutch is out. You either have to get used to it, or get rid of it.
I put fresh redline oil in my diff when i got it (it was just run in when i put it in my car.) It has about 5000 kms on it, and its always clunky, but damn good for corner speed (hooks up way better than std), and locking the rears if i need it (take off, and compression lockups) ;)
Sorry, but AFAIK your diff should not be making any noise when heading straight.
Certainly a locked or tight diff will clunk and carry on when you are turning, this is because the outside wheel is trying to turn faster than the inside wheel, so the inside wheel skips so it turns at the same speed.
You might have stuff worn out elsewhere in your drivetrain, driveshaft, cv joints, rear axles etc etc or the diff centre may not have been aligned properly....if not get it fixed as it will be much weaker since the gears will not be engaging properly
Yeh when going straight no clunking should happen..
Mine did last week (stock gtr diff) and it got worse so we pulled it out and some bearing failed and has caused the crown and pinion to loose teeth and stuff..
Not good!
I would get the driveline looked at as Duncan mentioned.
The AUS R31 skyline is famous for clunking and carrying on just as you have described. And it definately does not have a mech LSD.
I have one as a daily driver and get the same thing. Pull into the driveway at low speed, dip the clutch and then "PHWOOMP". Drifto described it well as feeling like a sledge hammer was swung under the car.
    • who can tell me what this is and why my car talks to me? i think it's hilarious. it's on my r34 right above the drivers-side storage compartment. the characters under the wrench say "inspection". every 10 or 20 startups, a voice starts talking in japanese from some speaker in this area below the dashboard. it says a few sentences then shuts off. different from the ETC card reader voice that happens every time i start the car. I've never found the speaker, i've never been able to catch the voice and translate what it says, and i've never found a forum thread that tells me how to reset the warnings. the holes in between the symbols are NOT buttons you can press to reset the warnings. anyone else have this? has the demon lord from Hereditary infected my car?!
    • Would you ever vent this bonnet or will it be unnecessary?
    • Happy new years folks! Wishing you all a successful year of money pit ownership!  So the subframe bushes are out....   Ok, who else has done that job before??  What a C U Next Tuesday of a job that is!  Be glad to not do that again in a hurry! I think I explored every option available to chop the middle section of the bushes out, most of them unsuccessfully! I tried a holesaw, die grinder, normal drill bit, air chisel, etc, etc. The true success happened by accident when I'd decided to try a step drill I spotted on the bench on the way passed.  See, there are benefits to never cleaning up after yourself! It RIPPED through so so much better than the drill bit. It has to be the skinniest one available so its small enough to fit between the inner tube and outer casing but it made easy work of it.  First one i hammered the shit out of... New method- 20250102_185506.mp4   I did the other 5 in less time than I fluffed around with the first one. With the first couple I used the cut off saw (sawsall as the yanks love to call them) to cut a break in the outer casings. Even with that they're still a prick to hammer or air chisel out.  The last few i just went rambo with the air chisel without cutting them. I over cut one of the early ones so will hit the with the mig to fill the cut then sand it off smooth.  The carnage left over-   I've also been "nesting" ie, cleaning up my babies nursery,  ie cleaning the f**king pig sty of a shed. I've got that much shit laying around it's as cluttered as my head!  Getting things put away, in boxes, on shelves, hanging off walls, all to get some working space back again.  Hopefully that keeps me motivated....
    • AFAIK does the base map for Haltech even have the 4D compensation enabled? It's been a while but when I looked at it I remember it was actually using pure TPS as one load signal and MAP for another. Seemed workable but not ideal by any stretch. A lot of people have "make the event-itis" which leads to stuff like this happening.
    • https://www.youtube.com/watch?v=qHhWelSBppY
