My go fast bits for the VspecII are hear, and with a bit of luck they will be in the car by next weekend.
Pictured in the below shots are.
RB25 airflow meters
Apexi pods
HKS dump pipes
HKS GTSS turbos
Trust remote oil filter and cooler kit
Apexi PFC and handset
Tomei PON type B 260/260 drop in CAMS
Blitz SBC SpecR boost controler
600cc Nismo injectors
Im also waiting on a Tomei 1mm head kit & Sump baffel
I already have a 90mm exhaust, carbon fibre cold air box and a twin plate ceramic clutch.
It should be nice once its all done and tuned, then I suppost I should head off to the drags to see how it goes, followed up with a full day at one of the tracks.
https://www.sau.com.au/forums/topic/69060-go-fast-central/
  • Replies 162
curious to know if this is the boost controller of choice at the moment? I would have to say I almost have a mirror image of bits on my garage floor.... sans the boost controller! I still cant work out which one to buy! I currently have a turbosmart 2 stage thing.... is that any good? (came with the car)
cheers....
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1280344
This is easy to answer, I wanted a dual solinoid, and the unit had to be small enough to fit into the ash tray. This one suited my needs. It just so happens it was installed yesterday. Everything was ok except for the boost gauge tube. It was not long enough and made from shitty plastic, so if you do buy it make sure you grab 2-3 meters of better tube. I actually need an english manual for it. I have set the boost to 1bar and it is working well, but it has so many functions and I dont know how to use it correctly. If anyone can help it would be appreciated.
Blitz SBC SpecR, english manual
As a side note, I also have the inj, airflow meter's, pods and untuned PFC install, boosted to 1 Bar, the car feels very nice to drive. Cant wait for the completed product!
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1281393
ok cool.... I was looking at a pack online that came with 3 m of nice blue piping.... seems to be a common thing with these items! about $450 too! I think the dual boost sol. is the way to go also.... please keep us informed when it is all tuned! I will be doing the same on my "old" R32 GTR soonish with a Jim CRD tune.....
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1281618
This might be a stoopid question, but one of those dumps looks a little funny, almost like it has an inner metal "skin".
If you look at the shot which shows almost the full length of the cams you can see down the exhaust end of one of the dumps, and the3re is a shiny metal ring that looks seperate to the flange, is that actually the case and if so why?
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1285685
If you look at the shot which shows almost the full length of the cams you can see down the exhaust end of one of the dumps, and there is a shiny metal ring that looks seperate to the flange, is that actually the case and if so why?
the flange ID is the same as pipe OD.. so pipe is smaller and does look silly just like you spotted.
so those hks dump pipes is only good for small size turbos like factory items, 2510/gtss is just about to get a little choked but still ok.
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1285961
  • 2 months later...
Well,
After a long journey the parts are all on, and the car is running.
Two weekends ago the engine came out, turbo's, dumps, cams, sump baffle and oil kit went on (I already had the PFC, Pods, AFM and boost kit on. The car was back on the road by Tuesday. We ran out of time so the head gasket did not get put on. So I have a 1mm Kit for sale if any needs one.
We had a couple of highlights. The crank bolt took 40 min to take off eventually taking two 100Kg men hanging off an 8ft extension pipe to crack. Finding I had no blow off valves, forgetting to tighten #1 turbo oil feed and finding out my clutch was gone and attempting to press out the HKS clutch bearing only to find out you open it with a small screw drive were amongst the highlights.
We had a couple of things to fix before I was happy with the car. Firstly find some BOV's. Judd was kind enough to lend me his HKS's which are now on the car. #1 turbo was still leaking some oil and water, the oil temp was not working and the boost was not being controlled (I had unlimited boost).
On Sat morning #1 turbo came off to find the oil return was not nipped up and the water feed copper pipes were not seated properly. The oil temp was a simple connector and the boost was fixed by blocking a return pipe.
The car is running well but I need to replace my clutch and get it tuned. Within a week or two I should be able to supply some power figures.
Picking a workshop to tune is proving to be a big step as well. Everyone has an opinion and everyone has good and bad stories. You have Ben at Bell performance, UAS, Adam at Just Engine Management, Croydon, Hills motor sport, City performance.
I’m thinking of borrowing an Air fuel meter and doing my own street tune!
The car feels strong but it will do better with a good tune.
Anyway I will let you know what I get when I dyno it.
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1418244
good work mate. that was my GTR being tuned at UAS when you walked into the dyno room covered in black sh1t to ask Ben how to remove the release bearing. I would have said hi but I didn't recognise you under all the grease!!
It was only after you left I realised who it was.
I'll be very interested to see how it goes mate.
https://www.sau.com.au/forums/topic/69060-go-fast-central/#findComment-1418308
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
