cams yes i have these - did not make a 'big' difference in peak power but more so in torque (100Nm)
pods yes i have these - would not make a 'big' difference in power though
what i am getting at is that the cams & pods cannot make the additional 120rwkw+ power difference
  • Replies 162
yeah, I don't think you can really compare the figures from two different dynos with any great level of accuracy. only really usefull to compare your own graphs, on the same dyno to get an idea of how you're going.
Paul, nice result with the SS mate. interesting that your old RS setup with no cams and 2.6l engine only made full boost at nearly 7000rpm. must make the new set-up seem a lot more fun to drive :P
What a load of crap, you don't gain 170rwhp going from awd to rwd
301rwkw by UAS???
CRD achieved 362awkw with my car - same turbo's & in fact similar setup.
as a comparison, this equates to 422rwkw!!!
...hmmm
maybe i have a "freak" engine (yeah right)
Marko.
Looks like he's saying rwkw to me? no mention of gearbox
yes I have to agree with Buster, would be a pretty poor driveline to be loosing 60kw just in switching from AWD to RWD. from my limited experience with my GTR and from observing others on the dyno i'd say the difference in a GTR between AWD and RWD on the same dyno is about 20-35kws.
Hi guys,
BU5TER:
its not 'a load of crap' that you lose up to 70kw from awd to rwd when a car is producing over 350awkw!
as Oz GTR02V added - with 300awkw you will lose 50kw from awd to rwd
formula for this:
the more power you make the more you will lose in the driveline, it is relative.
this is a fact guys!!!
i tend to take side with jim @ crd on this.
Marko.
whatever you believe is your choice...
what i write is from a professional that has been tuning gtrs for 15 yrs & is involved with international & national events, perhaps you should speak to crd if you have any further q's
i listen to experts & then relay feedback, how you choose to take this is entirely up to you...
marko.
I was in melb about 5 years ago and watched an R32 on a tafe dyno do 175kw @all 4 and then RWD did 210kw. CRD has done this before and I accept his statement as he has no reason or gain from bullshitting about it. The difference between his dyno is about 50kw between RWD and 4WD. Its a free country so make your own opinion and leave it at that.
no need for this negativity...
its sad that some of these informational threads people like reading such as myself turn into sour lemons :boohoo:
I promise you there are no sour lemons here :rofl: I just hate these informational threads being filled with bullsh!t to make one person look better then another or to bag a workshop that is a forum sponsor :(
I promise you there are no sour lemons here :( I just hate these informational threads being filled with bullsh!t to make one person look better then another or to bag a workshop that is a forum sponsor ;)
Mate no one was making anyone look better than anyone else...it was all interesting comparative feedback. Hence this is the aim of this forum to view, compare, obtain advice etc. Its great seeing different results. I also did not view any negative criticism towards a particular workshop. No one was taking offence to anyone and everyone respected and congratulated OzGTR02V's results.
In fact your the first person that has initiated any form of bulls%it saying that peoples comments were a load of crap!!! and that its cool if you want to be a puppet....now if thats not insulting well I dont know what would be??
I have also been to many tuners hence getting advice from an expert such as Jim is not being a puppet but merely being sensible by obtaining truthful advice and not advice from their ar$e.
Anyway lets get off the sour lemon topic and back onto the topic of congratulating Oz GTR...great results mate...awesome you must be proud. :(
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
    • Does anyone know ow what these two plugs are for and if they should be unplugged? Just put the dash back together and can't remember if these were plugged in before or unplugged! (Blue and white plugs) 🤦🏽‍♂️
    • Did some FASTing ...got the impression that the actual part# was a moot point ; seems all of these hardlines for coolant are discontinued/NLA... like, I take it you're after the hardline that bolts onto to the manifold...that's NLA according to amayama & nengun .... ...just to clear up some confusion, they typically mounted the AAC valve to the intake manifold somewhere near a coolant passage, so the body of the valve heats up & holds it open when engine's up to temp - no coolant flows through the valve, it's a mechanical, thermal connection.
