  • Replies 162
Well I had a quick tune done today, dyno's to be posted up when I can get a colour scanner, in summary
285Kw at all 4, with 19lb boost and 6800 torque.
The good news is
245kw at all 4 with 13lb boost.
I will chat more later!
PS I wanted a very SAFE tune for the track and I was not hunting peak power, so no
B!tching about 285 not being much.
I gotta say that people are getting very skewed in their perspectives if they think that 285awkw is "not being much" :D
That is MORE than enough power for the street and weekend circuit racing :)
Well done Paul :)
Neh, just got them cleaned. Nathan did it for me. Changing an air filter this week and will get an exhaust in the next month or so. And then we'll see what's happenning. After the injector cleaning and timing+idle adjustments it almost feels like carby car - no more throttle lag.
All,
As promised, below are my 3 dyno maps from last week. The boost hit 14lb and then dropped to 13lb. 245Kw at all 4 with 13lb makes for a fun drive. The other line on the graph is the default PFC, it was running lean which was a supprise, but more power with more saftey is the way.
Im crusing at 10psi around the street which is lots of fun.
My final figures at all 4 were as follows.
225Kw with 11spsi dropping to 10psi
245kw with 14psi droping to 13 psi
265kw with 17psi dropping to 16psi
282kw with 20psi dropping to 19psi
I tune was done by CRD cost $650
I asked for a safe road/track tune and I did not care about numbers.
I think I will grab one of those new pot belly cats and some cam sprokets and hope fully pop the 300 mark
congrats on your results mate!
this is the gt-ss setup right?
1 question:
if im not not mistaken...i remember you originally had the car tuned by UAS, it is now tuned by CRD - why the change?
pls correct me if im wrong :P
regards,
marko.
Marko,
I used to own a white R33 v-spec with GTRS's, its now owned by mik.
I now own a R34 VspecII with GTSS, check out the inital post for the complete kit list.
I used CRD due to Kabab with cheese's recommendations as he had a good outcome with his GTSS's.
My first option was to use UAS, I had my R33 done there them and I was happy but a retune on the same car by Bel yielded heaps more power.
I then wanted to use Bel, but I had a friend with a not so positive outcome and had a re-tune with JEM who said he was the best.
Kabab then highlighted the difference between JEM and CRD.
Im sure if I had UAS re-tune my car they could get more, but opinions about tuner's are like a$$holes, everyone has one. At the end of the day $650 for a CRD tune with dyno included was not offensive and I followed your's and kababs positive outcomes.
Deciding who to employ for tuning after spending $$$ on an engine setup can be stressful & daunting, I know i've been there!
...it is easy to lose trust & confidence in mechanics/tuners especially after being stung a no. of times.
Only "you" would know the difference in performance after Jim's tune @ CRD.:bananaman
Enjoy your car & tune!
Marko.
I found this old dyno from the R33. Below is the mod list but it really needed cams to get the GTRS's to do anything.
GTRS turbo's
Power FC & Hand controller
Power FC boost Kit
FMC custom 720mm x 360mm x 72mm
3" June exhaust
HKS cam sprockets
550cc Inj
Oil Cooler
3 Core Brass Radiator
Sump Baffle
Head restrictor
Metal head gasket
3000lb brass button clutch
    • I keep seeing supercharger kits for these listed on marketplace 😂
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
