Hi all,
I just had my car tuned at Hills (awesome tuner btw - thanks to all who recommended them) and got 177rwkw, which I'm damn pleased with. I'd like to know what my torque is though, but the car was dyno'd in 3rd and is giving me insane numbers. I think I saw a thread on this a while back but noone actually said how you can convert the number to the real torque.
Anyway, you can get my dyno sheet at www.ozemail.com.au/~caddies
Anyone know?
I'm sure it's got something to do with the 1.3:1 gearing on 3rd, but dividing by 1.3 certainly isn't giving me correct numbers.
Cheers,
Michael
https://www.sau.com.au/forums/topic/6907-torque-multiplier/
Yeah I'm still interested in figuring out the flywheel torque too :(
Out of interest what mods have you got and what boost are you running? My intercooler plumbing is killing my power, I'm going to get that sorted early next year. Every mechanic that sees the way the pipes are hooked up with right-angle bends gives me a worse reaction and a bigger speech on how crap it is. Mark's was the worst :D
https://www.sau.com.au/forums/topic/6907-torque-multiplier/#findComment-104004
OK I think I have nailed it. I think the answer to your original question is that your dyno is showing 2.33 times the flywheel torque after losses(I will explain what I mean by that later). I don't know why it's 2.33 but I will explain how I got there.
Firstly the I have used ratios from here which I think are correct. My car redlines at about 100km/h in second so I know the first one I had was wrong. So using this your max power at 129km/h is 6157 engine RPM, which seems fair. At this speed your wheels are doing 1084 RPM. Now given that kw=NmxRPM/9551, that means with 177kW the torque at the wheels is 1559.7Nm at the wheels. Thats impresive.
So I think what the dyno operators do when they set it to display torque at the wheels is reflect this back to the flywheel. eg. Torque=Nm@wheels/(Gear Ratio X Final Ratio). That would give you 274.56Nm at your peak power (you get the same figure if
you put 177 and 6157 into the Nm=kwx9551/RPM formula where RPM is engine RPM). This again seems fair because the torque at peak power at the fly with stock 184kw@6400RPM is 274.59Nm. So you are making about the same torque at the wheels as a stocker at the fly, but slightly less power at the wheels than stock fly power due to the fact your peak is at slightly less RPM.
Here is the spreadsheet with the right gearing. You can put in you tyre stuff, different speeds and power to find torque.
https://www.sau.com.au/forums/topic/6907-torque-multiplier/#findComment-104406
OK, here's a full list of my performance mods -
* HKS Type S FMIC
* HKS Cam Slide Pulley on the exhaust camshaft - 2 degress retarded
* Trust Airinx Pod Filter
* 3" front/dump combo pipe with a separate wastegate line, all HPC coated.
* Fujitsubo twin 3.5" catback exhaust
* Apexi Super AFC
* GFB Bleed valve (14psi)
* GFB Hybrid BOV (not really a performance mod, but it could affect how the car runs I suppose)
I think that's it.
Cheers,
Michael
https://www.sau.com.au/forums/topic/6907-torque-multiplier/#findComment-104454
b2barker,
That all makes a lot of sense. I am glad we finally got this all sorted out. I might copy and edit my dynosheet's Torque scale on the left to reflect what it should be. After all, even if I get it slightly wrong, I'll at least be closer to what it should be.
Cheers,
Michael
https://www.sau.com.au/forums/topic/6907-torque-multiplier/#findComment-104457
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
