yes i did search....
The only thread I found which was alot more help than the thing you linked was the following:
http://www.skylinesaustralia.com/forums/sh...sable+door+lock
did you read my question? -> nope!
What you've linked me to does NOT answer my question. I also have a series 2. Auto lock and unlock while driving is not a feature on series 2 cars. I even posted in that thread on the 3/10/2004. Gee... thanks for jumping to conclusions and branding me an idiot before you even read my question.
I am refering to the switch on the drivers door which you can lock and unlock the passenger door with.
Does anyone know of any other way of disabling this without "cutting the brown wire". Is there a fuse somewhere? Is cutting this wire the only thing that can be done to disable this switch?
Thankyou again.....
Hmm...I'm not sure how to do that.
Does anyone have a wiring diagram of the drivers door controls?
All I know is that the brown wire coming from there completes the circuit that unlocks the passenger door.
I've currently just shaped some plastic and stuck it either side of the switch.
can i ask why you want to disable it? just out of curiosity...
good luck getting it sorted.
I'm guessing it's due to the fact that someone almost had their car stolen recently and the switch in question was the method they were using to gain access (by feeding something through the window and hitting the switch to unlock the door)
what lazy-bastard said.
If you check it out it is actually really easy to hit the switch with a long, wide, thin metal object. In not very much time the passenger door would be open and nothing broken.
:rofl: well it will be good to find a secure way of doing it then... car thieves = ;)
can i ask why dont u just cut the wire?? i dont think its connected to a fuse as its only a relay to a door lock. you can still use the button to lock the passengers side door but it just wont unlock when u use it thats all. yeah i dont think the series 2 has the auto lock as my series 1.5 doesnt have it.
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
