I have a feeling that this particular turbo have steel inlet wheel.
Same ceramic exhaust wheel.
I would say that the boost and power levels would be close enough to the same.
I think on the series II R34, there was a 20nm hike in torque, but saem 206kw power rating.
BASS OUT
I wouldn't think so.
I'd say that there were either engineering computations that said the nylon compressor wouldn't suit the slightly raised torque, or they didn't want to do another build of the turbos because they were running the model out.
I thought that Japan had a max allowable output of 206kw by law, and everything was claimed to be 206 when in actual fact they were putting out more (closer to 220kw in series 3 GTT)
First they had the engine capacity restriction, until a clever guy invented the turbo, then they had a max power output to combat that. Next thing you'll prolly see is all carbon fibre or plastic panels to get a better power/weight ratio! =-D
  • 3 months later...
the 206kW isn't a law, its more of an unspoken agreement...
its like in golf, how you don't walk on someone's line on the green.. there's no law, its respect for the othere players game
cf respecting other car companies overall car quality rather than just their power output
And on the topic, i have an R33 series 2 turbo with 45v2 on the side, and it definately has the nylon compressor wheel...
  • 4 years later...
99% sure they are the same mate, differences between the RB25DET and RB25DET Neo are all internal not external, so parts like that should be a straight match.
Can anyone else with a bit more knowledge confirm that?
  • 2 months later...
Bump. I would like a confirmation of the above, as I need to have my manifold > turbo bolts done, and workshop suggested just going straight to drilling+retapping them which will be expensive. My other option is a NEO exhaust manifold off a mate for cheap, low kms. Will it be a direct replacement for my s1 R33 RB25 engine?
Also, how much are they roughly worth second hand for below 50,000kms?
Thanks
  • 5 years later...
not sure if its ba bf fg fgt
but I'm havin bad luck eit​her way motherf**kers :
The car I bought had bl​own the turbo and didnt get around to fittin the f6 one and bought an f6 car himself & lost interest.
​SO:
I got turbo all hooked up (f6), dump made, lines done then start up and oil in entry and exit of turbo and lots of smoke. FK
So I buy a r33 turbo for rego and cut/ weld its dump to suit and redo the lines and again FK I get oil out the dump this time... FK but getting money bak
So this arvy I'm getting an ​r34 turbo for reg, taken off a running r34 to upgrade. Temporarily I will run this until I sell/ rebuild & sell or rebuild and use this gt35.
this will be the 3rd turbo bolted to it in under 2 weeks lol.
xx​
  • 1 year later...
Hi all I'm doing a little research as I'm after stock reliability for my track car so going back to standard Nissan turbo on my r32 rb25det s2 from my aftermarket set up.
read this post and others -
what id love to know is what is the 'best' standard Nissan turbo to use.
i recently bought an Op6 then realised it has the single blade nylon compressor wheel (45v1) and rear steel wheel (shown as have having 6 point hex nut). From other posts I see this turbo is good up to 12psi.
Now this week mate wants to sell me his op6 turbo for a decent price - this turbo appears to have twin blade (metal) compressor wheel and 45v3 on it. What boost would this turbo be rated too -
overall which turbo is better??
No OP6 turbo has the bit I bolded above.  Regardless, any Nissan/Hitachi turbo with either or both of ceramic rear or plastic compressor should be run at more than 12 psi.  Not that this is the "limit".....they're just increasingly likely to explode as you wind the boost up and below 12 psi it's a bit less likely than it is above 12 psi.  Some die at 7 psi.
Realistically, there is no such thing as "stock reliability" when talking about these turbos.  Especially when talking about a track car.  That is the place where you will certainly kill them.
  • Like 1
That's how it looks when you run the turbo over 12PSI ..
Never found the turbine wheel I guess it went straight through the exhaust.
The compressor is nylon btw. (this coming off an 1998 S2)
Actually I was running this turbo at 14PSI for a while and thought I was lucky.
But when I went to the drag strip and floored it went on the first run :(
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
