I have a question regarding the headlights on an r32 gtr. My lights have a small round (domed) lens and the inner lense is rectangular (ish). When I put the headlight switch to normal low beam position the round ones light up along but when I put on the high beams the rectangle ones light up and the round ones go off.
Is this normal or is something wrong??
https://www.sau.com.au/forums/topic/69095-r32-gtr-headlight-query/
Yeah thats normal, i have no idea why nissan made them like that but they did. If you do a search and look around you will find some threads on how to link the high beam's to the low beam's and they will all come on at once. Also if you play with the stalk that engages the high beam's when you pull it towards you, at a certain spot all the lights will turn on :rofl:
can some one tell me if there were 2 different types of projector headlights used on r32 gtr? Mines an aussie delivered 91 model and I have projecter headlight that look like the have a round metal ring around them. Now i have also seen round projector headlight on later models that has a different sort of lens around them? are these brighter or different type of bulb used etc, I can make out H1 mentioned in the article (japanese article).
Hope someone can make sense of what i have typed.
For what it's worth, a while back one of the guys here mentioned there are 3 different types of headlights in the R32. There are 2 types of projector lights and the other type is the N1 set which has square headlights vice projectors.
If I find the thread, I'll link to it. It has all the answers :P
Mark
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
    • Either the installer needs to come back, you need an auto electrician, or you need to learn automotive electricals yourself.   First step Id look at is where that big thing came out of, is there still things unplugged at that location? Maybe they just forgot to put a relay in or something?
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
