Hey Guys, Unfortunately due to family circumstances it looks like im going to have to pass ownership of the goblin onto someone else. Price updated! I'm looking for 23K NEGOTIABLE
I've found something that has family approval on it so i'm looking to move the goblin very soon.
1997 Jungle Green S14a Body has 190,000kms on it, engine has 8500 since rebuild.
Specs are as follows:
Engine - Internal
New S15 engine
JE forged pistons with gapless rings
Balanced, shotpeened, linished crank and rods
ARP head studs
Tomei metal head gasket
HKS Step 2 256in 264ex 11.5 lift cams
Trust valvesprings
HKS rocker arm stoppers
HKS vernier gears
Engine - External
HKS GT-RS turbo
Custom steampipe manifold, coated
Hybrid FMIC
CES Dump (custom with larger wastegate pipe)
Fujitsubo catback
Z32 Maf
DE throttlebody (60mm)
Apexi pod
Cusco catchcan
Splitfire coils
Chiptorque daughterboard
Greddy Profec B boost controller
Apexi 740cc injectors
HKS fuel reg
Bosch fuel pump
Oil Cooler
32mm radiator
Nismo engine and gearbox mounts
Trust Sump Extension
Driveline
Cusco RS diff
C's short shifter
Suspension
Tein HA coilovers - adjustable pillowball tops
Tein adjustable radius (tension) rods - pillowball
Cusco lower arm brace
Roadholder front strutbrace
Cusco rear strutbrace
Whiteline adjustable front swaybar
Roadholder rear swaybar
Pineapples
Every bush replaced
Wheels/Brakes
Advan 17*8 17*9 rims
Azenis ST115 tyres, 235/40 front
Toyo Proxes T1-S 255/40 rear (brand new)
Brembo front calipers (R33 GTR)
Project Mu alloy hat 2 piece disks (front)
Z32 master cylinder
Cusco master cylinder stopper
R32 GTR rear calipers - seals were rebuilt 1500kms ago.
Other stuff
Nismo rear wing
Cusco 4 point cage (bolt in so can be removed if you don't want it)
SPA gauges - oil temp and pressure, water temp and inlet temp
Bride Zeta 3 bucket seat.
It's just got 12 months rego on it and has copped 2 services in the small time that i've owned it. I've only been able to put 4500kms on it in this time so the engine is basically 8500kms old. It's made 240kw@wheels in current tune but depending on how you want to set the cams up there's another 10-20kw@wheels in it if you dial it in for top end power rather than response. I'm basically looking for mid 20's or so but can be negotiable depending on a few things. If anyone is looking for a track car, or wants something very well sorted and quick on the track this could well be it! It's been seam welded in the lovely spot between the front guard and the door that 200sx's love to come apart to increase chassis rigidity.
This thing is just so easy to drive quickly on the track as was evidence of my first time out at wakefield with no previous experience, pulling off a 1:15 in the wet on low boost.
I can be contacted via pm or by email to
[email protected] .
Cheers,
Luke
https://www.sau.com.au/forums/topic/69099-fs-97-s14a-highly-modified/
still for sale people. Sad news is that Luke has been in hospital due to a broken ankle but will be home by weeks end.... anyone that may be interested is still welcome to come check it out :D:D:D
price - I know last time i spoke with Luke he was looking at offers around the mid $20k. Luke can confirm this when he gets home later this week....
Pics - i am sure Luke has some he can send you when at a computer
Hey Guys there's a few things that need to be taken into consideration now after i've broken my ankle and are unable to do a few things i would've liked before sale.
It needs a wheel alignment, the CES dump pipe needs to go back in as it's got a trust dump pipe at the moment... not that there is much difference really. It's about 2-3 kw up top and a little bit down low. Other than that it just needs a front bar as always due to it being "kangaroo modified" by the previous owner. I'm willing to take this into consideration on the price obviously. As i said i was looking for mid 20's but i can be negotiable, please make an offer if you are interested as due to my ankle it's just a garage queen now.
pics can be found here
http://photobucket.com/albums/y106/whoneedstherapy/
Hey Guys,
Price has been updated for one of the better setup 200sx's in the country. If your looking for a track weapon this is definitely a car to consider. If it wasn't for certain family issue's and a shattered ankle there is no way i'd sell it.
Cheers,
Luke
Must be sold, i have something else lined up to suit my crippled needs!!
Come on guys, someone must want an extremely well setup 200sx
It has a whole jap spec series 1 rear end on it. You'll notice that the rear bumper doesn't have any reflectors in it, nor does the bootlid have a brake light in it either. It is however a 1997 model series 2
  • 3 months later...
i dont know. guess its not for me then. good luck with the sale though.
hey guys,
This thing has to go as i'm moving out. Slight changes are now there's a power fc in there, making 245kw@wheels @ 20psi. Also it has 17x7 & 17x8 Avs model 6's on there in gold as well as a set of 18x9 & 18x10.5 SSR Sp1's that can come with it
Asking 23K negotiable
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
    • The funniest part I saw, was someone would bitch and moan on FB about something, Andy would be the one to respond, asking for more info, if he could contact them, what the engine setup is, what their config file was, and 95% of the responses were people just going "der! It doesn't work" and Andy going "What doesn't work?" And then going "The firmware!" And they'd go around in circles as no one could ever give information, and Haltech couldn't fault things on the bench, (especially when people wouldn't give any specifics).   Many moons ago, when Andy was back at e420c stage, he reached out to me, and asked me to test different plug and play looms for him (already had an e420c in the car on his V1 PNP loom). And he kept asking me, as I was competent enough to be able to give him some specific feedback on what was/wasn't working, how to replicate the faults etc, and work through things with him. Most people are terrible at answering the questions they're asked, or being able to provide quality feedback other than "it doesn't work".
