Just curious............we always see our jap cars done up but you dont ever see the old Ford Falcon done up. Why is that?? i under the impression that becoz aussie "blokes" buy them it like they dont wanna go under the "wog" impression by touching up their car. Reckn i am wrong and there is something else behind it.
Also i own a Ford Falcon BA model 2004, wondering how it would respond to a putting on minor mods like a bigger exhaust, maybe lowering for better turning coz it is a sedan so it is fairly high up and stuff.it says on the Ford site it is mean to have like 182kw of power.......does it respond as well to performance upgrades as other cars.
Lets discuss this !!!
https://www.sau.com.au/forums/topic/69119-why-not-a-ford/
You have obviously never been to a Ford or Holden "show 'n shine". In Vic we have a Ford day, at Geelong, with so many restored/modified Fords you don't have enough time to see them all. There is as much modified Fords as there is modified Skylines.
If you want to discuss Ford modifications i suggest you jump on www.fordmods.com or any other FPV site.
https://www.sau.com.au/forums/topic/69119-why-not-a-ford/#findComment-1279921
Being a 2004 model just remember, when you carry out any mods to your car it voids your new car warranty in more ways than one. I should know I work at Ford. If something even remotely related to the part you have modified breaks you will not be covered by warranty. I do feel sorry for those guys with XR8's, XR6/T, GT/P, F6 for being restricted during the 3 years of new car warranty of not being able to carry out mods if they want a warranty. It sucks. Good luck with your BA though, just a thought for you to consider. :(
https://www.sau.com.au/forums/topic/69119-why-not-a-ford/#findComment-1280227
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
