I have a situation where i'm having similar packaging issues. The plenum i'm likely to use is the one from RIPS
They do this one for around the $1400NZ mark:
user posted image
user posted image
user posted image
user posted image
For more info, try contacting Rob at RIPS -> [email protected]
I'm interested in any other's that peiople can suggest.
EDIT: D'oh
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1281396
it sure is a nice plenum.. would be interesting to do a bolt on test.. with a before and after test on dyno
but yer i might email him about it a bit later on in the day as thats all thats holding me back from putting my front mount on at the moment is a plenum... :D dont want shitloads of piping was thinking of waiting till the UAS plenums were made and trying one of them but yer dunno yet...
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1281421
i asked Rob some time ago and he said the plenums come :
The kit comes with plenim, enlarged throttle body, throttle cable, water pipe kit,all fittings for brake booster, map sensor, boost guage etc. All your original water temp senders etc go straight on. The tps wires need extending to go to the relocated throttle body.
The original idle controler etc can be retained if you are still running a stock computer.
I can custom paint the plenim whatever colour you want.
I can do a complete kit, painted, shipped
The photo above is obviously a shot taken as he was making the plenum...ie not fully finished :)
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282307
Well in my case the car is travelling at 0km/hr and looks like it will continue to do so until I find a solution for the plenum.
An aftermarket plenum at least gives me a chance of travelling at >0km/hr.
Why don't you use the standard one?:)
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282459
ok the pic of the insides of that plenum look like the top bit isnt welded up? :) im guessing thats a pic of everything hals way thru ? but well yer.. or wat is it 'you buy it you finish welding it'
I wouldnt be too sure. I would not be surprised if the internals look like that based on the fact that the aluminium welding is only fillet welds on the external surface, and has no penetration thru the wall thickness of the metal, (to the inside)
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282660
Sydney kid, he said, he cant use the orginal, it doesnt fit. This might mean the engine was mounted higher than it could have been, either way, it dont fit.
Roy, you can see light coming thru on that pic, Id say its not finished. Otherwise even if it is welded up, and just a bit messy, light should not get thru.
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282665
bahahhaha
you people saying its meant to be like that make me laugh... if light gets thru then she aint air tight and i highly doubt they'd sell them... so OBVIOUSLY its a work in progress pic! geez
and SK: he said due packaging issues he cannot fit the stock plenum.. So its not going in a skyline.. or of it is... a reeealy old one
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282679
Yeh, i suppose. Its possible thats light...or a reflection form the flash photography picking up an edge. I have circled what i thought could be a bit of penetration from the weld, or again it could simply be a tack...:confused:
Like i said, i dont know, but if i was paying the money, i wouldnt be assuming that its an incomplete manifold, and what im buying will be different. id confirm it with him:)
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282681
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1282683
Close. It's actually a mid 60's holden....and it's tight fit.
Height is probably not so much of an issue as ic pipework.
https://www.sau.com.au/forums/topic/69155-rb20det-plenum/#findComment-1283080
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
