Whats everyones view on the best way to get a High HP rwd car down the strip, doing it the hard way and sticking to manual box and radial tyres, im using BF Goodrich Comp T/A's.
I have a set of Bilstein shocks and some unknown springs and a set of stock shocks and springs now, and fully adjustable arms all round. Im tring to find the best comprimise on the rear between getting enough squat for increased traction and not to much so that the rear camber changes too much. On the front just aiming for some lift so we get weight transfer to the rear.
Ill be looking to get the bilsteins re valved for changes in bump and rebound and getting some springs made up. How much do the shocks affect the stiffnes on the bump and how much is affected by the spring rates ?
Also what afftect will sway bars have? i have whiteline bars on but my thoght was seeing we are going in a stright line and wont both the left and right sides to behave the same they will have little affect and if i remove them it may transfew to much to one side only and give major camber changes on that side where it would be under the most load.
Any ideas appreciated and what others have found through trying different things, cheers
https://www.sau.com.au/forums/topic/69161-rwd-drag-suspension-settings/
I still need help here please
Looking at getting some HR coilovers that have damping adjustment and then getting some different springs made with softer rate to fine tune the set up, will the shocks have suitable adjustment for drag work when using softer springs? The sprigs supplied are front 8 kg/mm and rear 6 kg/mm, so would get two different softer rear springs to start and go from there, any opinions
I've also got the same questions. I've bought a full set of stock suspension to use instead of my coilovers and have all adjustable suspension arms. Plan on using Comp T/As, Yoko A048s or MT radials.
AFAIK its not wise to change the spring rates in aftermarket coilovers as the coilover is calibrated for that stiffness (i'm sure someone can explain better). You're better off getting your stock suspension redone to 90/10 front and 10/90 rears.
Ok thanks look the goods are they any better then the BF comp T/As but, they appear to be a very sticky tyre and certainly fill the guards with lots off rubber from my small burnouts but i can spin then up so easy.
What setup do you have slapper and any qtr times?
    • This has been covered a bazillion times but google wet boiling point vs dry. Motul is only good when it's fresh, once it absorbs moisture it gets pretty average very quickly. So as above, make sure you change it if you're going racing. I run the Endless brake fluid in mind, but only because a mate is a distributor and it's cheap. It's not quite as good as SRF but I'm running 380mm rotors on a Skyline so it's not like they get hot.
    • That's the thing, they still add it and it makes fuel cheaper, implying adding 10% of it drops the cost of 91 by what, 5c a liter? I remember when it was barely half the price of 98. Because you know, 85% of what is in the fuel is way cheaper than 91 fuel is by volume.
    • Auto electricians that do repairs on automotive AC systems can source service kits. I don't know where they actually source them. I do know that there is one available for the R34 comp that I would need it for. If you have to pay someone to dismantle, clean and do needed repairs and fit kit contents, then you'd probably end up spending a good fraction of the cost of a new one. I would not be paying for that, because I would be doing it myself. My mechanic (bro-in-law) will happily source what is needed. Back in the day (like in the 80s and 90s), rebuilding an AC compressor was the standard approach, same as for starter motors, alternators, etc, because new replacements were v. expensive. After the China manufacturing boom and the rise of the disposable approach to everything, people just started throwing broken/worn stuff away and not rebuilding things.
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
