as the tittle states i was just wondering what AFM are prefered and recommended. i am looking for somthing that is straight swap or least difficult to adapt with standard GTR AFM and i am tossing up between the Z32 and the Q45. so far i have found that they are booth pretty much on par.
any suggestions? thanks
https://www.sau.com.au/forums/topic/69191-q45-or-z32/
cam, it was more.. which will just swap over with stock gtr afm's... my guess is as nismoid said.. dunno wat the plugs on standard gtr afm's are like but yer... z32's tend to be a common upgrade on gtr's from wat i have heard
Warrick,
What was more? what will swap with what? :confused:
The plug on a Z32 is 5 pin ;)
https://www.sau.com.au/forums/topic/69191-q45-or-z32/#findComment-1281871
Hi GTR94, if you had done a search you would have found out that GTR AFM's are 65 mm. A search would have told you that Z32 AFM's are 80 mm (same as RB20/25) and Q45's are 90 mm. By doing a search you would have noted that NONE of them are a straight swap over. They won't fit the airfilter box or POD's for a start, as quick search would have shown. The ECU will also need retuning, as per the search results.
PS; did I mention that you should do a search?
https://www.sau.com.au/forums/topic/69191-q45-or-z32/#findComment-1282024
it all depends on your rwhp level you want to run
my first
first choice
good up to 540rwhp and around $150ea second hand
rb20/25 are straight fit (same plug ) but will requires sum piping mods and tuning adjustment
second choice
good to around ~700rwhp and around $300 second hand + $30 plug
Z32 require a different plug solider in and the same piping as rb20/25 and a larger tuning adjustment
Q45 i have only seen on one car that was a 1100rwhp drag car(apexi's car)
all are relative easy to fit when running APEXI PFC as you can select afm at the touch of a button
cheers
pete
https://www.sau.com.au/forums/topic/69191-q45-or-z32/#findComment-1282246
There are 2 issues with AFM's, one is the restriction caused by the small diameter. The second problem is the one you hear about most often and that is the calibration of the hot wire sensor for higher airflows.
The Nismo GTR replacement AFM's I have seen are the standard GTR diameter (65 mm) with what look like Z32 sensors inserted into them (replacing the standard sensor). This fixes the calibration problem, but does nothing for the diameter based restriction.
:P
https://www.sau.com.au/forums/topic/69191-q45-or-z32/#findComment-1283525
there are a large number of cars running upwards of 330rwkw here in Vic now with the Nismo items.
They have no problem and results arent too dis-similar to others with say Z32's.
every car is different though.
Lee - will find out Wed
https://www.sau.com.au/forums/topic/69191-q45-or-z32/#findComment-1284621
