Will these rims fit?
Hi,
a guy i know is selling rims from his ford (17 inch) and i was wondering if they will fit my r33 gts-t? he says his stud pattern is 5x114.3. Might sound like a stupid question but i have no idea if they will fit? any of u guys know?
cheers,
Din.
I think the centre-cap on the Fords is larger than Skylines, so they will go on ok but there will be a gap around your centre-hub, meaning all the weight will rest on your studs which is bad.
Make sure you check this, if there IS a gap you can always get a collar machined up to fill it, but if you can try to put your wheels on his Ford if you can do a straight swap then you're sweet as else there's a problem (unless cause by calipers fouling or whatever).
 Share
