My car's idle has been pretty poor. Revs quite high when cold, and hunts continually when hot and when cold - even worse when the air con is switched on. It used to idle fine, this happened all of a sudden.
I have a power fc fitted, but it seems to be working properly. I thought it might be the O2 sensor as it doesn't have a constant voltage output, but ruled that out as the hunting will cause the O2 to fluctuate???
The car runs fine at cruise, and under power.
Has anyone had similar problems, or have any ideas as to what may be the cause.
PLEASE HELP
https://www.sau.com.au/forums/topic/6923-idle-problems/
Steve,
The best way to diagnose the problem is on a dyno, I know it cost's money but compared to the hassle of going through all the possibilities it will be worth it.
Other than that it could be plugs, injectors, O2 sensor, temperature sensor, fuel pump etc. The list of possibilities is quite long, a dyno will narrow that down very quickly and then you can have a happy car again.
See'ya
https://www.sau.com.au/forums/topic/6923-idle-problems/#findComment-102447
Thanks heaps for your replies:)
GTS-t VSPEC:
I will be dyno tuning the car again soon, just waiting for the Z32 AFM. Can you recommend anyone in Perth?
fatz:
don't have a lightened flywheel YET - thanks for the tip though as this is a future planned mod.
blind_elk:
What and where is the AAC valve, and is there a specific way to clean it?:)
https://www.sau.com.au/forums/topic/6923-idle-problems/#findComment-102722
Steve,
There are quite a few good tuners in Perth, I tend to use either Steve at SST or Barry from Barries Dyno. How much is the Z32 AFM costing? I run a map sensor, therefore no restriction from the AFM, does the PowerFC have map sensor capability? There is also a VPC (vane pressure converter) from HKS or someone that provides the equivalent electrical signal without the restriction. It's just for the cost of the Z32 AFM I think there are better alternatives, but that's my opinion.
I would have thought the hunting is a fuel related problem. Good luck with the retune.
See'ya:burnout:
https://www.sau.com.au/forums/topic/6923-idle-problems/#findComment-102729
GTS-t VSPEC:
Thanks again, the Z32 is costing $270Aus which isn't a bad price. The reason I don't want to go map is that it seems to raise some problems with fuel usage at idle and cruise and from what I heard takes a bit to set up properly, with the added advantage that upgrading the turbo doesn't require a complete retune. I may be way off the mark, but I was under the impression that MAF is alot more street friendly than MAP. The Power FC has an option for a Z32, so its a pretty easy install and then a dyno tune, and I believe not compatible with MAP?
RAIDER:
Cheers for the input, I'll give it a go and see what happens. Fingers crossed
https://www.sau.com.au/forums/topic/6923-idle-problems/#findComment-102938
At that price for the Z32 you'd be crazy not to buy it. Yes in general I would agree with most of the fuel issues relating to the MAP, but most decent tuners can set it up no problems. It depends how far you want to go with your setup, as even the Z32 will run out of range with a decent turbo.
Seeing as the power fc takes the Z32 directly then it is a good choice, I hope it turns out well once you've had it retuned.
See'ya :burnout:
https://www.sau.com.au/forums/topic/6923-idle-problems/#findComment-103143
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
