Hi All,
I have just bought an R32 and i love it, the only thing is i want to know how to fix its issues myself instead of paying for mechanics to waste time trying to figure it out. Could anyone pls provide me with the 32's Manual, worse comes to worse i will have to buy one but if i can just download it why not.
https://www.sau.com.au/forums/topic/69236-pls-help-r32-gts-t-owners-manual/
  • 1 year later...
I tried that link that you put up. It doesn't work anymore. Are there any other links that anyone knows of? I'm looking for an owners manual for an R32 GTR.
I found one for an R33. I think It's the GTST though. I'm not sure.
http://www.bitenova.nl/tt/1azfd
Edited by cactu5
Try google, it always works. I found one for you within five minutes. Here's the link...
http://www.esnips.com/doc/cbd3944d-6036-4d...d-Bookmarks.pdf
Easy huh :)
Hope its english though, when i looked for my R33 manual, I downloaded 2 jap ones before I found an english one. I didn't bother checking this one, but it should be ok. Didn't want to wait for 25 megs at 1:30am :(
If not, just type 'skyline r32 (pdf)' into google and go through all the pages.
Edited by R33-GTS
i also found that one, but its for a GTR and were both after a Gts-t :devil:
i did a pretty thourugh search using a few different methods and searches but couldnt fin anything.
I was under the impression you used the GTR servoce manual in conjunction with the RB20DET supplement?
there is no translated r32 GTS-t service manual
there is a translated r32 GTR service manual
there is an r32 workshop manual with all engines, including rb20det
i use the GTR manual for doing stuff to my GTS-t. haven't done anything where the combo of engine manual and GTR service manual was not sufficient so far. and if it was that technical, i probably wouldn't be doing the job myself.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
