Just received an email from the local transport officer from council stating the change in demerit points in NSW applicable as of TODAY! thought ppl might be interested...
> Applicable from today !
> Speeding fine and demerit point change.
> The penalty for speeding up to 15 km/h over the limit has increased from 2 to
3 demerit points. For light vehicle drivers (eg cars, motorbikes, vans, etc)
the fine has been reduced from $130 to $75, while the fine for heavy vehicles
drivers remains $199.
> 3 points also apply for speeding up to 15 km/h over the 40 km/h school bus
speed limit.
> The penalties for speeding more than 15 km/h over the speed limit remain
unchanged.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
